02-07-2024, 08:59 PM | #1 |
Rep 5
Radiator fan
Hi everyone, so i’v been wrking on my e70 i had a starter replaced few months ago,once done my battery died , got a new battery registered to the car and everything, long story short my radiator fan is not kicking inn so i got a new relay hoping that would solve the issue butt no, however the only way my fan will run for few seconds is if disconnected and connected right away it runs for a few seconds then it dies , anyone has any idea what coukd be wrong?
02-07-2024, 11:10 PM | #2 |
Rep 391
Does it need to run? How do your engine temps look? It should only run when needed.
StradaRedlands4946.00 |
02-08-2024, 05:31 PM | #5 |
Rep 391
02-09-2024, 10:23 AM | #7 |
Rep 101
If your disconnect the fan and reconnect it and it runs for a bit seems like its getting the signal. I would check the connections at the fan side, see if you can clean it best you can and maybe add some dielectric grease.
Same error code as the thread below, it was fixed by cleaning the connector at the fan. https://www.e90post.com/forums/showt...FIgnition%20ON.
2011 E70 Xdrive50i M-Sport Black
2011 E92 M3 ZCP LeMans Blue 2006 E90 330i Silver - Donated after 410,000 miles |
argento538.00 StradaRedlands4946.00 |
02-20-2024, 07:17 PM | #9 |
Rep 5
So i was out of the states for a while didn’t get a chance to work the issue however I disconnected my temperature sensor and fan run full blast, that way i was able to bring the car home, that means there is an issue with the signa going to the fan am assuming , and yes my bad it is celcious .
