10-12-2016, 11:03 PM | #1 |
Rep 1,909
Changed front Drive shaft myself - Pics inside
hey Folks, heard some horror stories so I changed the front shaft today, to my utter surprise the two shafts look IDENTICAL .. It breaks from U clamp and the two U clamps are of the same width and not at all reinforced.... attached are pics
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
03-21-2017, 08:09 AM | #3 |
Rep 1,909
on my own from the dealer, they wont recall our 2012 X5
03-21-2017, 12:06 PM | #4 |
Rep 2,737
2012 is now part of the recall, my dealer has me set up for a replacement. The recall goes all the way to 2013 now.
03-21-2017, 03:17 PM | #5 |
Rep 1,168
If I'm not mistaken, both pre- and post-recall shafts should look identical, the difference is u-clamp manufacturer.
There're aftermarket products with longer ends, but that's a different story. |
03-22-2017, 03:48 PM | #6 |
Rep 1,909
I got mods
03-22-2017, 09:20 PM | #7 |
Rep 2,737
03-23-2017, 09:21 AM | #8 |
Rep 76
03-23-2017, 01:28 PM | #9 |
Rep 2,737
03-24-2017, 11:28 PM | #10 |
Rep 1,909
says i have no open recalls....
03-27-2017, 07:47 AM | #12 |
Rep 12
Go here and put in your VIN:
http://www.bmw-rp.com/production/isg...nsf/submit.xsp Does driveshaft show up? You may be able to be reimbursed your costs. |
04-05-2017, 08:43 AM | #13 |
Rep 254
Purchased a 2010 E70 M in Texas on Saturday, drove it home Sunday, took the kids to school Monday, and snapped the front shaft right in the middle yesterday.
At first I was devastated, but I'm handy, so figured I'd replace it myself. Shafts are less than $150 on eBay shipped in masses... So... I'm following your foot steps soon it seems. How hard was the job? 4 bolts up front and a crow bar in the rear? Fluid drain out and refill on completion? Thanks in advance. |
04-06-2017, 10:12 AM | #15 |
Rep 415
04-06-2017, 12:11 PM | #16 |
Rep 254
Correct. BMW NA advised this was not under recall and to contact my local service center. Local center quoted $1500...
Bought shaft on EBay for $140... looks simple. 91% cost savings. Hooray for day 3 encounter with BMW Service. |
09-26-2017, 11:49 AM | #17 |
Rep 18
2011 X5 with 55k miles. I've been noticing what appears to be misfire/hesitation upon acceleration. Getting worse over time and more noticeable when vehicle cold. (250 miles since felt and now) Felt exactly what you would expect with bad coil pack or plug. (no codes) Replaced them all and no change. I was convinced it was the Valvetronic motor or system causing misfire and prepared to spend 1,100 at indi BMW shop. Only noticed symptom when the x5 was warm. They could not find it (but testing while cold) After warm-up they felt the mis. I get a call the next day to say it was the driveshaft and was an outstanding recall and i owed them 415 for diagnosis. I didn't believe them and thought they couldn't find issue and was sending to dealership, using driveshaft recall as excuse. Same day, Friday I drove to the shop had them remove the front drive shaft again, so i could test run before i paid. Ran like a dream, absolutely no or hesitation. Ran it without front shaft over the weekend was perfect. Appt at BMW was Monday and picked up today. The x5 seems to shutter just as it did when i first noticed the issue. 250 miles ago. I wish i took photo of old shaft, it looked brand new. WHAT IS GOING ON?
09-26-2017, 02:10 PM | #18 | |
Rep 1,727
First, they charged you 415 for a recall item? yeah i wouldve fought that Second, are you saying after the recall you are having the same problems? Any thought about perhaps the transfer case or transmission problem?
2017 C63 2012 X5M SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i |
09-26-2017, 02:14 PM | #19 | |
Rep 2,737
09-26-2017, 09:53 PM | #20 |
Rep 18
Indy shop can't do recall and i think they thought I would be happy to pay 415 since it was less than the 1,100 I anticipated for valvetronic issues. Shady, yes! I did pay and even told the actual mechanic who diagnosed it that if he was correct, i would buy him lunch for a week. I removed the new shaft tonight and runs like a dream. -c- is on the right path i do believe, but I still have hope it could have something to do with actuator. Since the actuator controls the front axle torque by applying pressure on the plates isn't it plausible this could cause the slip? Only other clue is it gets worse as the fluid get warmer. I did get a 4x4 error along with others and during that time it ran great. There is a ghost code showing D36A but its not currently set. I also have ISTA+ but really don't know how to effectively test with it. If it is the ATC-700 what are my options for replacing? Reputable re builders? DIY? I have a lift and pretty handy but these tasks always seem to turn into double the work and adding to the cost of a pro. Does 3k sound right for part?
09-26-2017, 10:36 PM | #22 | |
Rep 18
The actual problem is not a faulty front drive shaft but rather a faulty transfer case that when it fails it locks up and the momentum of the moving car stress fractures the shaft at it's weakest point and takes the TC with it. Much cheaper recall for BMW to blame it on the shaft rather than faulty TC. |
