      03-23-2012, 12:01 AM   #1
bavarianx
bavarianx's Avatar
Drives: 2006 X5 4.4i
How to install BMW TPMS
We thought that it would help out them members to go over the correct way to install TPMS in most aftermarket and OEM wheels. There will be slight differences if you have multi-piece or older wheels that are NOT TPMS friendly. They may require an adapter.
First you will need your new TPMS sensor and correct size valve stem.
You should have an extra washer and holder stick with them valve kit.
Attach Torx valve screw to base of sensor.
Insert valve stem into new wheel. Make sure it is a standard valve stem hole.
Add single washer.
Attach valve stem nut.
For BMW's BERU/HUF TPMS set torque tool to 35in/lbs.
Tighten to torque.
Most shops will have a TPMS testing tool to make sure the sensor is activated properly and ready to perform on your new set of wheels.
Done. We would like to thank the guys at ShopTPMS for the great pics. Post up any questions you have. Thanks
      03-23-2012, 07:12 AM   #2
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Thank you for the info. Any idea on torque specs?
      06-30-2013, 01:43 PM   #3
awd301
Drives: bmw x5 3.0D 2007
How much does it cost one unit?
      06-30-2013, 01:53 PM   #4
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25085
Drives: '22 Chalk Gray Porsche C2S
To add to this....
...some wheels will need stems from the manufacturer (..a'la BBS). When I had LM's on my M3, I had to order TPMS compatible stems from BBS.
