06-29-2016, 03:54 PM | #1 |
Rep 29
2011 X5 annoying whistle/whooshing noise
I have a 2011 X5 that whistles off and on and I was hoping someone might be able to diagnose. It sounds like the car is gasping for air or in a wind tunnel.
The sound is not constant. It mainly appears at low RPMs going up hills. The cabin air filter is new. The noise was there before and after replacement. See the video below. The first whistle is around 8 seconds, then it appears again at 19 seconds. Its the loudest at 29 seconds. |
06-30-2016, 12:37 PM | #4 |
Rep 144
maybe a seal broken under the hood or a damper stuck for the air vents? have you tried changing the inside / outside air vents to see if it related to a/c heat?
06-30-2016, 01:16 PM | #5 |
Rep 29
06-30-2016, 03:18 PM | #6 |
Rep 937
06-30-2016, 03:33 PM | #7 | |
Rep 29
I have received the low power mode/limp mode error a few times but that goes away after restart. Seems to be a problem with others on this forum with no definite fix. What's a "valve stock"? |
11-03-2018, 11:50 PM | #11 |
Rep 2
Drives: 2011 X5 35i
Zombie thread...
I have this same exact problem with my 2011 E70. What was the final diagnosis? |
11-05-2018, 01:59 PM | #13 |
Rep 2
Drives: 2011 X5 35i
Huge help! Thank you!
