01-14-2018, 07:43 PM | #1 |
Rep 212
Drives: 2008 e90 335i, 2012 X5 M spor
2012 xdrive50i rough acceleration
Guys,
I took the car to the shop to get some work done, but the shop could not figure out why the car has a jerking acceleration. They hooked the computer to it but couldnt find any codes. I dont think its a motor mount issue but you never know, it seems as if the jerk happens when shifting but after its in gear you feel it all the way up. It started off subtle and then had gotten more noticable. I have replaced all coils and plugs and the issue still persists, just seeing if anyone has had this issue or know where else I can look. |
01-18-2018, 10:12 AM | #2 |
Rep 449
Fuel injector?
Transfer case? These trucks have a lot of power, have you tried to duplicate the concern with the traction control off, maybe its wheel spin being combated by the traction system, and it translates to you as a jerking acceleration. Are all your tires the same tread thickness, they could cause a jerky feel with AWD.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD 1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about 1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter |
01-18-2018, 06:21 PM | #3 |
Rep 212
Yes tires are all the same, and i am not peeling out and dont know if i could with AWD, i am not even stomping on the accelerator just when i drive normal i feel it and when its in gear it doesnt go away. If injectors that would have thrown a check engine light or code right?
I will try disabling the traction control and check. Thanks for your help |
01-19-2018, 11:37 PM | #4 |
Rep 212
Traction control didnt make any difference.
01-20-2018, 10:28 AM | #6 |
Rep 327
Unplug the connector to the transfer case and try. It's never truly disabled until the connector is pulled underneath the car. If the problem goes away you know where the issue lies. The TC also has a plastic servo actuator gear that gets stripped out but usually will cause jerkiness during a turn. I second the transfer case + adaptions reset, and/or transmission oil + adaptions reset. Any jerkiness or resistance when you let off the accelerator (does the car coast normally)?
01-23-2018, 02:49 AM | #8 |
Rep 212
When i coast the car feels fine, when i am not accelerating and maintaining speed it is also fine. Just when i need the engine to pull is when i experience it.
01-23-2018, 06:47 AM | #9 | |
Rep 1,689
From what you're describing, it's either your injector(s) or a vacuum/vent line leak. They have very similar symptoms. Matter of fact, a vacuum leak can cause misfire codes. Look for any black soot on your bumper around the tailpipes, that can be a dead giveaway for faulty injector(s). Look for any oil around the vacuum/vent lines/pipes. It can be very obvious when they crack but usually it's not. There will be a thin coat of oil where they are leaking. Also, when my injectors were on their way out, the vehicle didn't throw any codes right away. It usually took a few of days for it to show a CEL and register fault codes. |
01-24-2018, 09:20 AM | #10 |
Rep 449
Lets start with the transmission and transfer case checks, the TC is the weakest link in these trucks, it may lie there. IMHO
01-25-2018, 01:51 AM | #11 | |
Rep 212
01-25-2018, 07:24 AM | #12 | |
Rep 1,689
If all that checks out, and the vehicle does not register any fault codes eventually, JoeyBimX5din could be on to something. Worst case scenario, your transmission is slipping or a bad torque converter. Any way you can record what you're experiencing and post a YT link? |
01-26-2018, 01:16 AM | #13 | |
Rep 212
01-26-2018, 07:15 AM | #14 |
Rep 1,689
Didn't think of this yesterday but could it be that your fuel pump (HPFP) is starting to give out slowly? It's possible that the vehicle is running rough at higher RPMs if it's not getting the fuel it needs. When the N54 guys had issues with these, eventually the cars wouldn't even start.
01-29-2018, 01:43 AM | #15 | |
Rep 212
Thanks for the help guys! |
01-29-2018, 07:32 AM | #16 | |
Rep 1,689
I don't know how to tag names on threads so try to PM him directly. |
01-29-2018, 08:43 PM | #17 |
Rep 65
Subscribed.
I've been having (what I believe is) the same issue for quite some time. Eventually I got tired of dumping $ into it and people telling me I'm crazy, so have just been living with it. Mine is most noticble in "M" mode with manual or S shift. There's a noticeable and delayed kick when on and off throttle. I've done throttle adaption/reset and had a full software update, though still persists. I'll be interested to hear what your symptoms boil down to. |
02-07-2018, 02:03 AM | #19 |
Rep 212
02-07-2018, 02:04 AM | #20 | |
Rep 212
02-27-2018, 08:45 AM | #21 |
Rep 1,689
03-04-2018, 12:40 AM | #22 |
Rep 100
Sounds like something electrical to me. Particularly if the engine is essentially cutting out and causing the jerking. I had the same problem once (not a bmw). The engine was jerking because I had a starter wire that was touching an exhaust pipe and it melted the insulation and it grounded out the entire electrical system causing the engine to jerk.. Eventually the wire caught on fire. That was really fun. By the way, if only 1 cylinder is loosing its spark, then it will cause a slight miss and you will feel it a little, but It wont really jerk like "all cylinders" are deficient and basically Not Pulling at all. That would be a larger problem, like the whole electrical system is being shorted out or not supllying enough current for spark. If the jerking is really large then you would have to suspect that it was not only 1 cylinder that was failing to fire. instead it would be more likely that all cylinders are not firing. And if all cylinders are intermittently not firing, then changing all the coils would not help. Because each coil only serves 1 cylinder and the likelihood of all coils going bad simultaneously would be like the odds of getting struck by lightning or winning the lotto.
When you put the engine under a load, more spark is required. It might be whatever device that feeds the coils, and I do not know what that it because I do not have the diagrams.. or it might be something as simple as a sensor that is misinterpreting where you are in the throttle and subsequently is not boosting the spark. It does not sound like a fuel problem to me. Fuel pumps pressurize the entire system to a peak value. If your engine was being starved of fuel at only under a load but idles fine, then I think you would just have a loss of performance, but no jerking. And it would not really run lean because the 02 sensors would try to keep the mixture at 14.7:1 like it is programmed to do. So, if you reduce fuel, then it would compensate by having less performance, but no jerking. good luck |
