      11-09-2017, 05:37 PM   #1
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Advise for f15 owner regarding Valve stem seals in 50i engine
Hi everyone,
It may seem I'm posting in the wrong forum, but I think you guys are the one who has knowledge about Valve stem seals issue in n63.
I checked realoem and it looks like n63tu uses same valve stem seals, same design engine basically with crazy hot cats located right in the back of engine slowly frying everything and especially rubber components (seals, gaskets, hoses etc)
I was wondering if you can share some knowledge for us f15 owners of how to avoid expensive repair and maybe any remedy available that you know of?
1. How often this happens, can someone approximately say like in 10% of all 50i engines or more or less? Just to have rough idea
2. Is it true that it happens more to stop-n-go traffic driven cars and less with mostly highway driven cars - as I've heard heat is main enemy that stiffens rubber valve stem seals and they become rigid and non compliant? Allegedly highway cruising has better cooling and engine is not overheated as much as in city traffic - not sure if true
3. Are there any oil additives we can use with every oil change to add and protect, condition or rejuvenate valve stem seals? I've heard AT 205 - is it good?
4. I've read on German forums that there are 2 main remedies to prolong life of 50i engine - low temp thermostat (like X5M uses, I think it's around 90 degree Celsius thermostat and opens earlier and helps keep engine cooler) and the other remedy is to install downpipes to eliminate heat from cats
5. Any other advice you can share please?
Thank you very much!
      11-10-2017, 04:41 AM   #2
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
AFAIK, the newer valve stem seals (used from late model E70, and all F15) don’t suffer the preliminary failure as the one it replaced.
DuSh2113.50
      11-10-2017, 08:19 AM   #3
Pierce330
Pierce330's Avatar
Drives: E90 328 xDrive
Is your X out of warranty already?
E46 330i (Sold)
E90 328i (Sold)
E90 325i (Sold)
E90 328i xDrive
DuSh2113.50
      11-10-2017, 08:26 AM   #4
philly42
Drives: X5M, Z3M
Seems that you might be fine since you have the updated seals.
Keep in mind valve seals are an internal engine part...the rubber is made to withstand high temps. Your engine and oil cooling system should keep temps in a range where they are meant to run perfectly.
Going with a lower thermostat will affect a lot of other things and will not fix the valve seal problem.
Keep in mind valve seals is nothing new with engines. Focus on things that are new will point to the problem...for example
-Direct Injection
-Extended Oil Intervals
-People wanting to cold start the car and drive
Out of these 3 things direct injection may have the most affect on seals. Prior to direct injection, intake valves were always cleaned by the fuel injectors. Removing this allows build up from the valves from the combustion chamber. There's also build up from the crankcase ventilation system constantly coating the area with oil film.
Walnut blasting is a common procedure with direct injection engines. The reason it's not marketed for our v8s is because of the labor cost involved. (most cases the engine needs to be removed)
So just because we have intakes on the bottom side of the engine doesn't mean we're immune to the disadvantages of direct injection.
https://www.newtis.info/tisv2/a/en/f...old/1VnYvs8OBw
Installing an oil catch-can will help stop the build up of oil and film in that area.
Not sure about this but, water/methanol injection may help with the cleaning.
Shortening the oil interval should help renew the additives lost over time. Some additives are made to help swell up the rubber valve seals. Though you have to constantly use these additives...it's not a use once-fix-the-problem-forever.
Personally from a cold start I let the car sit at least a minute before considering driving off. Synthetic oils are much better than conventional oil so you may not need to do this.
One of the best things to do is spend a lot of money and have walnut blasting done
DuSh2113.50
      11-10-2017, 08:53 AM   #5
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Thank you all for replies! It's reassuring to know that this issue is not as bad as it was. I'll definitely shorter oil intervals and look into walnut blasting and installing oil catch-can!
I have 2014 x5 and warranty is up in 5 months. Extended warranty is $6k which is a bit pricey to be honest, but with all advise you guys gave me I may be just fine
      01-14-2018, 11:01 AM   #6
perry8912
Drives: bmw x5
I’m in the same boat, did they really fix the problems that n63 has? Any other reliability issues during your ownership?
Thanks
      01-16-2018, 12:43 PM   #7
heatmizr
Drives: E70 X5 50i M-Sport
Is there more detail about this? When did they start installing the up-rated seals ?
I have an e70 Feb 2012 production date; knowing if these seals were the later type would be a big relief for me.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      12-12-2022, 05:44 PM   #8
vanremog
Drives: 2014 X50i
N63TU has the same problem with Valve Stem Seals
The notion that this has been solved in the F15 N63TU engines is false. Mine failed CA smog at 86Kmi due to long idle visible smoke, despite less than 2qts oil usage between 5Kmi changes. Tried all of the other fixes, but no dice. Your state may pass this, but not CA. Not a question of IF, just WHEN it will happen to you. Getting the stem seals done currently at an indie shop because BMW wanted me to pay $8K portion of $20Kmi engine replacement. They don't want their dealers doing just the stem seal replacement due to tying up their tech time.
      12-13-2022, 10:07 AM   #9
cayx5
Drives: 2012 X5 5.0i
2012 5.0i owner here. 65K since engine was replaced in 2015. I'm told frequent oil changes are most important. More than one tech has recommended 5k mile intervals. If you do mostly highway 7.5k might be okay. The original 15k interval, then shortened to 10k during CCP work, was a big part of the problems experienced early on. My BMW indy said that they have seen N63's with 80k that were problematic and those with 130k with few issues. Their take is that the cars that are driven hard (beat on was the exact words) have the most issues.
I've inquired about Liquid Moly's Motor Oil Saver to extend life of VSS. Tech is neutral on the product but didn't say don't use it. My research tells me that it helps prolong the life of the rubber and may try it down the road. My indy shop uses Liquid Moly oil so there should be no compatibility issues.
Since I had a N63 engine replaced in 2015 (still the N63 and not the N63TU), I've been trying to find out if my BMW remanufactured engine has the updated VSS that went into the N63TU. Logic would have it that the improved seals would be used since they are the same size but the dealer that did the work can't confirm. Anyone with knowledge of this please advise.
I also removed the plastic engine cover for slightly better heat dissipation.
      12-17-2022, 06:35 PM   #10
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Ya its a 40+ hour job for an experienced tech, expect 60+ hours if you do it yourself. Tools out there to do it you can rent if you want to tackle it. Scale of 1-10, its a solid 8. I am at 185k miles now in mine, 50k miles after doing it myself and still no oil usage so worth it if you want to keep your X5 for the long haul.
As other members mentioned:
Change oil every 5K
Use LiquiMoly 5-40 Leichtlauf oil
Use 2 cans (pre-mix with oil) of LiquiMoly Mos2 additive
Open your hood when parking in safe areas so allow heat to escape
Avoid stop and go traffic if at all possible (take the long way on the highway)
Take off your engine cover
