      04-03-2014, 08:04 AM   #1
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
How to remove rear tail lights?
Does anybody have instructions on how to remove rear tails? Please post
THX.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      04-03-2014, 06:38 PM   #2
zerrantoss
Drives: 2011 X6
I've just done it last week to install the blackline tail lights.
It's pretty easy to replace. Took only 30 minutes.
There are two pieces on each side.
Big piece:
1. Open the side panel from inside, so you can gain access to the light assembly's connector.
2. unplug the connector
3. there are 3 nuts close to the connector. Take them off
4. push the light assembly outwards from inside. They will come off easily
Small piece:
1. Open the tail gate
2. You should see a small piece of plastic cover. Open it with a flat head screw driver
3. Unplug the light's connector
4. There is a white plastic "hook" holding the light assembly, with a nut at the top. Loosen the nut so the hook comes off.
5. Remove the light
      04-03-2014, 06:39 PM   #3
denaliman
denaliman's Avatar
2013 X6M  [0.00]
Awesome! thanks much!
      04-16-2014, 12:19 PM   #4
zerrantoss
Drives: 2011 X6
No problem, glad to help
      04-20-2014, 10:51 AM   #5
PapaB
PapaB's Avatar
Drives: '10 135i,'07 MCoupe,'09 X6 5.0
Please post some pix of the new blacklines and where you got them.
Thanks.
      04-15-2015, 11:27 PM   #6
Trusnow
Trusnow's Avatar
Drives: 2014 740li xdrive
i just installed new black line lci tail lights today and it was easy as 1 2 3.
