05-21-2019, 10:32 AM | #1 |
Joint Chiefs of Staff
24279
Rep 190,975
Wagner Tuning EVO III Competition Intercooler For the BMW X5 & X6
The BMW Competition Intercooler Kit EVO III has the following core dimensions (535mm x 332mm x 150mm / stepped, 19,2L). The high performance intercooler core provides a 113,5% larger frontal area and 120% more volume compared to the stock mounted intercooler. Our engineers have increased the intercooler core size and efficiency, as well as improved the endtank design to remove any OEM bottlenecks, resulting in increased flow rating and charge cooling properties. We use our award winning WAGNERTUNING Competition Intercooler Core which is made specifically for this application. Constructed of the highest quality Tube Fin intercooler cores with inside turbulators combined with cast aluminum endtanks optimized by CFD for best possible internal airflow. The original charge air hoses can still be used. The result is excellent cooling properties and a lot less pressure drop then the stock intercooler. Despite of itīs size the weight of the complete intercooler is only 12,5kg. This Intercooler Kit is the best choice when it comes to performance gains and low intake temperatures. All of our intercooler use an anti corrosion protective coating with perfect thermal heat dissapating character. Optimal cooling with clearly more power. Kit is ready for installation, 100% perfect fit. Easy installation - plug and play. All of our products undergo rigorous quality control. The BMW Competition Intercooler Kit from WAGNERTUNING fits to the following cars:
kit comes with:
