      06-15-2020, 04:56 PM   #1
ncmoore12
ncmoore12's Avatar
Drives: 2013 BMW X5 M
2013 BMW X5 M  [0.00]
LED Low Beam Malfunction
Hey Everyone!
I have a 2013 E70 X5M with LED headlights.
Recently I have been getting a Low Beam Malfunction where the drivers side low beam is turning off. If i turn off the headlights and turn them back on it goes away. It was happening a lot one drive and I came back and checked and cleared the codes and then it was a awhile till it happened again, but hadn't been driving as much. Sometimes it happens quite a bit over the course of a drive.
I am getting the following fault codes from Carly when it happens:
00AD0C - LED head light module (LHM) left: detect LED high beam
00AD0A - LED head light module (LHM) left: detect LED low beam
Yall think I need to replace the entire LED headlight assembly or just the main headlight module or the headlight control module?
https://parts.bmwmonterey.com/a/BMW_...t/63_1051.html
https://parts.bmwmonterey.com/a/BMW_...D/63_1495.html
Thanks in advance!
2013 E70 X5 M - SG
2001 E39 530i - M-Sport, MT,TB
2011 E93 335i - M-Sport, BSM
      06-17-2020, 04:29 PM   #2
Lunker325
Drives: E70 X5M / 991.2 C4S
I think you would be good to just replace the control module. Since that module is on the bottom of the headlight assy it may be getting moisture into it and causing issues.
I also have the LED headlights and get the same issue you are having every once in a while. Mine always happens when it has been sitting out in the rain and the headlight switch is in the "auto" position when I start the car. Cycling the headlight switch on and off fixes the issue until the next occurrence. I started turning the headlights to off when leaving the car and rarely get the error any more.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune
      06-18-2020, 09:05 AM   #3
ncmoore12
ncmoore12's Avatar
Yea that is the solution i use to, seems to go off right away. And i think that may make sense, it seems to only act up after rain now that I think about it. Yea maybe i'll start doing that, i'll keep an eye out for a control module that isn't $500. Thanks!! I am pretty sure it is a pain in the ass to get to too.
2013 E70 X5 M - SG
      06-19-2020, 01:58 PM   #4
Lunker325
I've been looking on eBay for the control module, lots of them on there.
Front bumper and wheel well liner needs to come out at the least, so lengthy job but not too difficult!
      09-21-2020, 12:35 PM   #5
ncmoore12
ncmoore12's Avatar
Still haven't fixed it yet, hopefully going through the fender liner and not taking the entire assembly out but following the following instructions:
This is what i bought:
https://www.ebay.com/itm/OEM-Lear-BM...276a%7Ciid%3A1
Fender liner removal:
https://www.newtis.info/tisv2/a/en/e...light/B9vzwc2j
Headlight control module removal:
https://www.newtis.info/tisv2/a/en/e...ght/1VnXrTvehn
2013 E70 X5 M - SG
      09-24-2020, 06:28 AM   #6
Lunker325
Good luck on the install, looking forward to how difficult it is and if the new part works.
      10-15-2020, 11:56 AM   #7
ncmoore12
ncmoore12's Avatar
Does anyone know if you have to code a new headlight module if you install it or does it just work?
2013 E70 X5 M - SG
      11-30-2020, 07:26 PM   #8
OllieX5M
Drives: 2010 BMW M5 and 2002 BMW M3
dont have an answer but i have a fading driver side LED headlight. What should i replace so its back to normal brightness and matches the other side.
      12-01-2020, 09:19 AM   #9
ncmoore12
ncmoore12's Avatar
After replacing the LED Main Light Module and Corner module, i haven't had any issues, didn't need to code it according to the dealer, all the dealer would do is clear codes is what they told me.
OllieX5M
For the Fading headlight, hmmmm not sure on that, most LEDS are binary like on/off, never heard of fading, it doesn't throw any codes does it? Does a quick google search find anyone with the same issue?
2013 E70 X5 M - SG
      12-01-2020, 05:35 PM   #10
OllieX5M
Yeah it seems like my driver side light is pointing down and the right side is pointing further up the road that’s why I feel it’s not as bright is there a way to adjust them?
Tags
headlights, led, low beam malfunction
