      03-19-2015, 02:44 PM   #1
Kerrazy
Drives: X6M
Bmw Heater Function Why Bmw?
So from day to day cold to warm temperatures outside. Why can we not just turn up heat by turning temperature? we also have to hit the vent control button which in turn displays on the IDrive, then adjust from cold to hot or whatever we require... And then the temperature knob will correctly adjust..Does this not seem redundant and only specific to BMW?
There must be a reason to have this additional step or setting. On my previous bmws it was a blue/red rotary knob then actual temp setting.
Someone explain this
      03-19-2015, 03:48 PM   #2
mitch808
Drives: 2012 X5 35i
'cause German engineering.
      03-19-2015, 04:36 PM   #3
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
whats worse is, there's a setting to shutoff rear climate control .. kids weren't getting any heat and that setting turns on/ off by itself atleast couple times
did u try auto ?
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      03-19-2015, 05:04 PM   #4
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
I think it work if you leave it on auto, the good thing is we have 3 fan modes in auto, so I have always just left the system on auto and adjust the temp which will make the system compensate for the change in temps
      03-19-2015, 11:16 PM   #5
Kerrazy
Drives: X6M
Nope if you have set in blue on I drive and digitally turn up heater, it blows harder but not as hot as when set in red. Must be a reason. If I find out I will post.
      03-20-2015, 01:30 PM   #6
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
don't get me started on the temperature knob adjustment...seems very redundant, they should have just made it like a home's thermostat...
Anyways, it's recommended you simply use the auto feature and the HVAC will adjust fan speed to the desired temperature.
here's some discussion from the M3post...they talk about the "wheel" for hot/cold, which is the equivalent of the digital knob that you're talking about for the X5. On the M3, it's not digital, it's a wheel:
All other concepts are the same with the E70, in short, BMW designed it so you can blow heat/cool air to your body, and separately blow heat/cool air to your face.
http://www.m3post.com/forums/showthread.php?t=750638
http://www.m3post.com/forums/showthread.php?t=547298
      09-25-2015, 10:54 AM   #7
heatmizr
Drives: E70 X5 50i M-Sport
With the cooler temps rolling in I just realized I had the same question as the OP myself. I thought my heater was broken as I could only detect heat when the dial was on the max temp setting of 84 F. All other temp settings produced just cool air. Turns out I was not in AUTO mode, and had the iDrive vent control on full Cold, for summer)
So just yesterday I realized that if I pressed the dash Vent button and moved the knob up to Hot, and I got plenty of heat. (again, in Non-Auto mode)
So it seems the iDrive onscreen dial setting just sets the temp for anything other than the AUTO function; reading the two links above I think confirms that. They could just put some indication on the iDrive screen for temp that states "Manual Temp control" or similar that could clue ppl in.
I have been impressed by the AUTO function too, particularly on the e70 because it has three intensity settings. Our e90 doesn't have this, and therefore never used AUTO on that car. I am beginning to appreciate AUTO on the X5 though, and just cycling through Soft/Medium/Intense settings.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      09-25-2015, 01:09 PM   #8
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
This is just to adjust the mid vents, compared to the complete setting..
Read the manual once.. Then you know.. No need to change always..
      09-25-2015, 01:23 PM   #9
yoandry
yoandry's Avatar
693
Drives: G80 M3CX & X5 M50i
Move down to Florida and forget about the heat option for life. jk
