03-18-2016, 02:03 PM | #1 |
Rep 775
265/285 with spacers?
For those of you running a 265/285 tire set up, are any of you also using spacers? And if so could you post pictures? I tried searching in the 15 page long thread about spacers but i couldn't find any. I had a 15mm/18mm when i was running a stock tire set up and now that i switched to the bigger size i didn't put the spacers back on. Was thinking maybe 5mm in the rear and 10 in the front?
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
03-25-2016, 12:12 PM | #2 |
Rep 655
Drives: 2015 F82 M4 Blk on Blk, DCT
I run 265/285 and use 12mm spacers up front and 15mm spacers in the rear. However, I'm not on stock wheels, so we have different offsets.
When I was on stock wheels and tires I ran 15mm up front and 20mm out back. So I imagine you can easily run 5 & 10 or more depending on the look you prefer. I like the bulging out of the wheel well look personally. heh.
2015 F82 DCT M4. Max PSI Built Motor, Ported head, Full Bolt Ons, Upgraded fuel system, Motiv Reflex and flex hardware for flex fuel, Max PSI Crank Hub Fix, Pure PS2+ Turbos, SSP Spec X clutch, xHP Trans Flash, DSS Axles. Custom Ecutek tune by Ian @bend calibration. 780whp & 700+ ft lbs torque, 18" HRE R101s.
03-31-2016, 01:37 AM | #3 |
Rep 597
I run 255/285 on 20" with 9mm out in front and 8.3mm in rear for the offset of the aftermarket rims.
Was thinking of putting the 285's in front and getting 305s for the rear. Not sure the 285's will work. also my car is lowered on HR super sports.
2015 F82 M4 Yas Marina & Full SS - All pkg/opts but CCB. Xpel - All painted surfaces
MPerf Electronic steering wheel, MPerf pedals, IND (reflectors, vents, grill, engine cover), Carbon Fiber (side marker, seat backs, shifter surround, e-Brake, rear spoiler). Pure S2 turbos, MPerf Exhaust, Akrapovic DPs, BM3 (Cary Jordan 657rwhp+), H&R springs, 20" AvantGarde rims |
03-31-2016, 09:04 PM | #4 |
Rep 7
I just upgraded my tires to 265/285 Bridgestone RE71R's and tried using my 12/15mm spacers with my new setup. The 15mm's on the rear work well and look very aggressive. The 12mm's up front were causing rubbing on my fender liners so I removed them. I'm on stock 19" wheels and stock adaptive suspension. 5mm will definitely work but I'm wondering if 10mm still rub. Anyone try 10mm spacers with 265 tires up front?
04-01-2016, 10:12 AM | #5 | |
Joint Chiefs of Staff
4920
Rep 115,999
How do you like those.. I literally just ordered a set Need more grip! Mike |
04-01-2016, 10:13 AM | #6 | |
4920
Rep 115,999
Mike |
M4David0.00 |
04-01-2016, 11:47 AM | #7 | |
Rep 2,997
FYI, my intention on 18" wheels and stock suspension is to go 265/285 with ~10mm spacers front and rear.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
04-01-2016, 04:55 PM | #8 | |||
Rep 7
04-01-2016, 08:40 PM | #9 |
Rep 2,105
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
Stock wheels with 10mm rear and
12mm front Vorsteiner wheels with 5mm front and 3mm rear
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | Last edited by AM4ZING; 04-02-2016 at 03:22 PM.. |
04-04-2016, 04:28 AM | #10 |
*_*
811
Rep 3,160
Installed MPSS 265 / 285 set-up, and it feels great. Car is on Swift springs and has 12mm spacers all around. No rubbing. Digging the fuller / meaty look vs. the Contis I had, fills up nice. Car has -2.0 camber all around, neutral toe front and a tad +toe in rear.
04-04-2016, 01:41 PM | #11 |
Rep 2,399
04-04-2016, 02:01 PM | #12 |
Rep 2,105
Thank you! I also agree that the stock 19's paced out look perfect on these cars
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | |
04-04-2016, 03:23 PM | #13 |
never could compete with Lloyd Braun
5276
Rep 5,378
Sweet! Got any pics?
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
04-07-2016, 08:17 PM | #15 | |
Rep 3,452
04-19-2016, 07:53 PM | #16 |
*_*
811
Rep 3,160
Tried the set-up on track and it felt solid. Towards the end of the 20 min session started to get a lil greasy, but still fine given they're not r comps.
To dial out some of the tail happy nature of the car, I took out the spacers up front and left them in the rear, what I believe would simulate wider track in the rear, and it worked like a charm. Coming in hot on a couple turns the car was very confidence inspiring / stable. In the chicanes, and high speed turns, it performed flawlessly, really felt like a solid set-up. Note, running the car on Swift springs. |
04-24-2016, 12:43 PM | #17 |
Rep 231
Front: Bridgestone RE71r 265/35/19 12mm spacer
Rear: Bridgestone RE71r 285/35/19 15mm spacer KW HAS Spring on lowest setting in rear No rubbing |
Aesthetic_M41.50 bmwbrad22249.00 |
04-24-2016, 12:58 PM | #18 |
Rep 10,176
06-17-2016, 02:14 PM | #20 |
Rep 775
you'll be fine, i'm running that same set up with no issues
2020 M340i xDrive |
06-17-2016, 05:55 PM | #21 | |
Rep 838
265/35/19 RE71R - Section width 10.7", Tread width 9.6" 275/35/19 MPSS - Section width 10.9", Tread width 9.5" What do you think?
19 MBB M5C
16 Yas MarinaM4 (gone) 05 E46 M3 HPF/ProEfi Stage 2.25 (Gone ) |
06-17-2016, 06:39 PM | #22 | |
Rep 231
I would have had a real world answer on rubbing with the Re71r on swift for you, as I was supposed to have Swift Springs installed by end of day today, but the shop didn't get it done. I'm pushing it with the 12mm in front, and think it will be very close with your little bit of extra width, might be worth it to run the 10mm. |
