07-30-2019, 12:32 PM | #1 |
Rep 557
Please help understand TPMS system.
I have a 2012 X5 which I bought new, and it came with 18" rims. I have just purchased a set of 19" factory take offs from a F15 X5, and I will use the 19's with summer tires, while the old 18's are going to become a winter set used with winter tires.
I am trying to figure out the whole TPMS situation. The stock 18's have stock TPMS which works properly. The new 19's also come with TPMS, but I understand F15 TPMS does not work with E70. Should I purchase new TPMS from the dealer? Will it physically fit the new rims? When changing the wheels, will I need to reprogram something every time? |
07-30-2019, 04:41 PM | #2 |
Rep 357
Nah no need for dealer. Find HUF NORTH AMERICA “OE” sensor with the correct built date of your vehicle. The date cut off is around 9/2010. So find the one that is made for after that date since yours is a 2012. HUF has another one that has the “INTELLISENSE” that needs to be program. So make sure you get the OE one that you can just reset your tpms on your iDrive each time you swap the set out.
Theres other brand too that is cheaper and will work. As long as they are labeled OE that means theres no programming, just relearn iDrive reset. |
07-30-2019, 06:45 PM | #3 | |
Rep 557
https://www.pelicanparts.com/catalog..._pg3.htm#item9 Part #: 36-10-6-856-227-BOE (Superceded) New Part# RDE-012-INT |
07-30-2019, 11:18 PM | #4 | |
Rep 357
07-31-2019, 04:43 AM | #5 | |
Rep 557
Here is Denso from Rockauto - https://www.rockauto.com/en/moreinfo...7%2BGuVPMOSl1y However it says "When a TPMS Sensor fails, you'll want to replace it easily with a DENSO First Time Fit® TPMS sensor. Unlike one-size-fits-all sensors, DENSO has developed sensors that never need to be programmed or cloned before installation – they're built to the specified vehicle right out of the box {note: new ID numbers will need to be registered through the OBD II port}. With DENSO, installation is a snap — their TPMS Sensors relearn just like an OE part, restoring the vehicle to its original condition." First of all, how do I register these new ID numbers through the OBD port, and will I have to re-register every time I swap winter/summer set up? If I went with the dealer, do I still have to go through the registering process? |
07-31-2019, 07:44 AM | #6 |
Rep 357
That instructions is much of universal explanation and not directly Bmw terms(relearn/reset iDrive). However if you look closely to the pic of the denso its got the part # stamped on it “rde012”.
07-31-2019, 09:23 AM | #9 |
Rep 7,485
You can also call around to your local tire retailers (like Discount Tire/Tire America/Bell Tire/etc) and see if they can give you a good deal. They will also have the tools to activate the sensors. Sometimes an aftermarket TPMS requires activation.
Discount Tire charged $45 for HUF sensors in DEC/2018:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-01-2019 at 09:20 AM.. |
08-03-2019, 12:22 PM | #11 |
Rep 525
x5 n00b here, piggybacking on this thread as I'm curious. Sounds like a direct TPMS system but I haven't noticed a pressure readout in iDrive. Is it like our Subaru, which is the worst of both worlds, uses direct TPMS but doesn't do a readout (only tells you when one is low)? or am I missing a screen somewhere?
08-04-2019, 10:24 AM | #15 | |
Rep 7,485
Checking your "cold" tire pressure should be a regular thing one should do regardless if you have the direct or indirect TPMS system. The owners manual should give details on what occurs if a tire gets low (should get a warning)...and the iDrive screen should indicate WHICH tire is low if you get the tire pressure warning when you pull up the screen in iDrive (low tire will be yellow/orange instead of green).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 08-04-2019 at 10:39 AM.. |
08-04-2019, 02:33 PM | #16 |
Rep 99
Good info as usual, Q.
They key to buying the right sensors, as stated earlier, is the build date of the car. There are some versions of aftermarket TPMS that won't communicate with the BMW system, depending on build date (ask me how I know). Get the right part number. |
08-07-2019, 08:33 AM | #17 |
Rep 709
Pressures AND TEMPS? Now THAT is slick...
heatmizr [Todd]
g26 i4 e40 - Clean Machine e70 X5 50i M-Sport "The Boss" Loaded e90 328i - sold e36 M3 - Gone to become a track star |
08-09-2019, 11:57 AM | #18 |
Rep 557
Big thanks to everyone who helped for the info. Purchased and installed the sensors from Rockauto, installed the new rims, and everything functions properly - just had to do reset in the i-drive system.
10-12-2019, 12:00 PM | #19 |
Rep 6
Drives: 2010 BMW X5M + 2014 Z4 35i
Hi guys, I am also having a TPMS problem. I have tried to swap out the RDC module under the dash, but that didn't change anything. I searched for the TPMS Sensor using this post, but I do not have a sense located in this spot: https://xoutpost.com/1121861-post40.html
Any ideas on where the sensors are? I have a 2010 X5M. I assume the build date will have something to do with it....but I dont know where to look for that information either. thanks! |
10-12-2019, 01:27 PM | #20 | |
Rep 357
The link you provided with the picture is pointing to the rdc module. Tpms are on your wheel valve stems. |
01-28-2024, 04:40 PM | #21 |
Rep 2
Tagging onto this post... I have a Right Front Tire Low warning on the iDrive. Reset it and it comes back after a couple miles. Swapped the RF and LF tires, reset again and the iDrive still says it's the right tire that's low. Bad RDC?
01-28-2024, 07:43 PM | #22 |
Rep 34
I had the same problem with TPMS I just coded it out and enable FTM
StradaRedlands4940.50 |
