02-13-2011, 10:31 PM | #1 |
Turbo Engines are Fun
24
Rep 252
New ///M Metal Pedals Installed today...
I am very happy with the results. I found these on eBay, and decided to try them because they were so much less, and looked better than what BMW has to offer. They are well made out of thick aluminum with rubber treads.
I ended up needing to remove the gas pedal, but that was an easy removal as it was held in with one bolt. The hardest part was removing the wiring harness connector, until I realized that you had to squeeze it to unlatch both sides of the connector from the sensor assembly. I then had to remove the pedal from the sensor base, but that was easy also. I carefully drilled the holes and got things mounted and put back together. It actually FEELS better, the gas pedal has more weight to it now. |
02-14-2011, 02:16 AM | #3 |
Rep 75
Good choice ! i have the same with footrest
Excellent grip |
02-14-2011, 11:11 PM | #7 |
Rep 1,265
Drives: 2011 BMW X5 Sport
Are those reps or real ?
2011 X5 Sport
Black Sapphire w/ Black Perforated Nevada/ DK Bmboo Technology/ Vented Seats/ Cold & Convenience / Multi Contour seats/ 20" wheels and more... 2004 Mustang GT Vert. - Modded |
02-15-2011, 01:46 PM | #8 |
Rep 283
