      05-03-2011, 06:50 PM   #1
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Turned my non sport airbag into a sport airbag
So I had always wondered if it could be done in my 3 series, ended up trying it with the X5. Have a non sport wheel and swapped it for a sport wheel in my 2011 X5, purchased an airbag cover from ebay for $100 and removed the old non sport cover and replaced it.
It is a pain in the ass to work the 15 or so clips loose that hold the cover on, but once you get it started, it took me about 15 minutes, new cover slides right on and clips in.
Quite a bit cheaper than purchasing a new airbag and is reversible if you needed to put it back.
Wish I had taken pictures, but I just started taking a look at how I would go about it and kinda got into it before I thought about the camera.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      05-03-2011, 08:33 PM   #2
dhirm5
Drives: 2014 M5 ZCP, 2014 X5 35d
so now you just have to hope it works when you need it...
2017 Porsche 911GTS - Agate Gray on Black
2009 Aston Martin DBS - Casino Royale Gray on Black (sold)
2014 M5 ZCP - Azurite Black over SSII Full (gone)
2009 M5 - Carbon Black over Sepang Full (gone - not forgotten)
2001 740i M-Sport - Carbon Black over Black (gone - not forgotten)
      05-04-2011, 04:04 PM   #3
roadkillrob
I am reasonably, the airbag is a contained unit under the cover, so the chance of failure mostly would come down to not fully clipping the cover into place, which would result in the airbag still deploying after firing the cover off the steering wheel, but I triple checked all the clips!
2008 E93 335i FBO
      05-06-2011, 08:08 AM   #4
smallseafishie
Drives: AW 07 e92 335i + AW 11 X5 35d
2007 E92 335i  [0.00]
so did you replace the wheel or just the cover?
Can you take a picture of the final result?
Thanks!
      05-06-2011, 03:29 PM   #5
roadkillrob
Thanks!
I replaced the standard steering wheel with the sport wheel and then replaced the standard airbag cover with the sport one (saves buying the sport airbag in it's entirety)
2008 E93 335i FBO
      06-06-2011, 04:16 PM   #6
smallseafishie
Do you mind being a little more specific in what you did? I just ordered a msport wheel so I'll be in a similar boat as you were.
Thanks!
