      09-03-2023, 08:47 PM   #1
brettF
Drives: BMW X6 2011
12v constant supply location? - Trunk
Hi members, I have just acquired an 2011 X6 E71 and unlike my old E53 the 12v socket in the back is only on when the engine is running.
Is there a location I can tap into a 12v supply to run aftermarket trunk light and small fridge when need be.
Ps: possibly this has been covered but my searches haven't found anything.
      09-13-2023, 05:21 AM   #2
roberthowie
Drives: 2022 Honda CR-V
You can tap into a 12v supply from the fuse box in the trunk. The result provides a diagram of the fuse box and the location of the fuses for the 12v sockets. You can use a fuse tap to connect your aftermarket trunk light and small fridge to the fuse that corresponds to the socket you want to use. You can also use a multimeter to check which fuse is hot all the time and which is switched by the ignition.
