02-19-2023, 10:02 PM | #1 |
Rep 1
Bmw x5 tire size
I just bought a 2008 bmw x5 4.8 and he included a extra set of tires and wheels there 21's 295's on front and 315's on rear but got told thats to big for the front is that true or can i run them?
02-20-2023, 10:15 AM | #2 |
Rep 1,054
Should be okay. The only thing to look out for is coming into contact with the upper ball joint but with the 21s you should be okay
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
02-20-2023, 12:20 PM | #3 |
Rep 398
The diameter size difference between front and back might cause issues with the transfer case.
You don't mentioned the profile, but I don't think there is a combination of 295/315 where they are close enough in diameter that it would be within what BMW would consider acceptable so it may cause abnormal wear or cause issues with overheating of the transfer case |
02-20-2023, 12:23 PM | #4 | |
Builder of Special Cars
202
Rep 484
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
There is only a few tires out there that have the same rolling circumference but are different in width (typically only the OEM fitments that are made for the car brands) |
03-09-2023, 06:05 PM | #5 |
Rep 204
I definitely agree that tire size is off and could mess up your tranny. To be safe you can be 0.7% size different not 3%. You need 285x35x21 in front and 325x30x21 or 275x35x21 front and 315x30x21 rear. These all will give you a 0% difference.
