02-18-2023, 11:47 PM | #1 |
Rep 7
Drives: 12 BMW X5 xDrive35i
No Crank only Click
Hi, I have an E70 X5 xDrive35i.I recently found out I was having ground issues. So, I had tried the jumper cable remedy which worked i was driving the car around for a little bit just to charge up the battery and all of a sudden, my car had shut off while idling and I see smoke coming from my jumper cables melting. At first, I thought it was my battery, so I had tried jumping it that didn't work either all I heard was a click from my starter that's all. I have replaced the battery it is still the same issue. Checked all forums no one seems to have an answer for it. I hope one of you guys have a solution to this issue.
02-19-2023, 06:52 AM | #2 | |
Rep 282
Using the jumper cables to ground are just meant to help diagnose, I would never drive around with them under the hood. |
02-19-2023, 02:16 PM | #3 |
Rep 7
No I haven’t replaced the ground cable as of yet
