      11-14-2013, 09:39 PM   #1
Centrofly
Centrofly's Avatar
Drives: X5M
Some new shoes today....
Got rid of the run flats for some fresh 22 in pirelli's. So far love them feels lighter and more nimble. Prepping and cleaning old wheels and will be up for sale soon. Trying to decide on applying spacers. Need some feedback. Thanks
      11-14-2013, 09:42 PM   #2
Centrofly
Centrofly's Avatar
Drives: X5M
Size:  205.5 KB[attach][/attach]
      11-14-2013, 10:09 PM   #3
larryv
larryv's Avatar
64
Drives: 17 M3 ZCP 11X5 M Sport 20 I3
Looks good, for sure rear spacers.
      11-15-2013, 05:55 AM   #4
Centrofly
Centrofly's Avatar
Drives: X5M
Thanks.
Just the rears? Was thinking turner motorsports.
      11-15-2013, 08:01 AM   #5
Chio
Chio's Avatar
Drives: G80 M3 Comp Xdrive
2018 S6  [10.00]
agree rear spacers!
      11-15-2013, 11:01 AM   #6
Singh97
Singh97's Avatar
Drives: Jattizm
2004 BMW e46 M3  [10.00]
Looks very good. Agreed spacers will make the stance perfect. Go with 25mm rear and 12mm front.
BTW where did you sourced that wheel/tire set from?
Singh
      11-15-2013, 11:57 AM   #7
slim
Drives: 2013 BMW X5 35i
Nice! What size tires are on those 22's?
      11-15-2013, 03:24 PM   #8
larryv
larryv's Avatar
64
Check the Classified JYohay
FS: 25mm X6/X6M/X5M 25MM H&R spacers 100.00 Bucks
      11-15-2013, 07:05 PM   #9
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Nice! Now you need a coat of Optimum Opti-Cote 2 to keep them rims pristine.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      11-15-2013, 09:34 PM   #10
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
What on earth is that? Tell me more please. Good for powdercoated wheels?
      11-15-2013, 10:34 PM   #11
denaliman
denaliman's Avatar
2013 X6M  [0.00]
It is a coating that is clear. It is not wax, but a resin bond to protect painted surfaces. it is permanent. Although it won't repel brake dust it will protect the wheels and makes cleaning a lot easier. I don't work for them or am affiliated in anyway. I just like their products. I will post a link below for information. FYI, If you apply this to Matte black it may give it a bit of a sheen. There is lots of info on detailing forums. If this information is in violation of forum policy the moderators will I am sure remove. I am just attempting to contribute to the forum community.
http://optimumcarcare.com/ocoat1.php?li=10
The professional choice for PERMANENT paint protection.
Optimum Opti-Coat 2.0 is a permanent coating that protects automotive paint over its lifetime! Unlike a wax or sealant, Optimum Opti-Coat 2.0 will not wash or wear off. It acts as a second layer of clear coat which provides increased protection against the elements. Formerly only available to professionals, Optimum Opti-Coat 2.0 is now available to the public in a more user-friendly formula.
Optimum Opti-Coat 2.0 is a clear resin coating, much like the clear coat that already exists on your vehicle. And just like your factory clear coat, Optimum Opti-Coat 2.0 is meant to be permanent! Optimum Opti-Coat 2.0 can be applied to all exterior surfaces. It is not recommended for glass since improper application can affect visibility. For other exterior surfaces, Optimum Opti-Coat 2.0 is a highly effective, transparent protective coating.
Optimum Opti-Coat 2.0 can be applied to:
painted surfacesIt only takes drops of Optimum Opti-Coat.
headlights
wheels
plastic trim
bumpers
aluminum & chrome surfaces
Optimum Opti-Coat 2.0 is an additional barrier between the elements and your vehicle's paint. The paint will retain its color and contaminants will be blocked out to keep the paint smooth and clean. Unlike waxes and paint sealants that require frequent reapplication, Optimum Opti-Coat 2.0 provides constant, unyielding protection for the life of your vehicle's finish!
Optimum Opti-Coat 2.0 uses a resin technology that forms a permanent bond to paint and cures, just like an extra layer of clear coat.
Once Optimum Opti-Coat 2.0 cures, washing is the only maintenance needed to keep your vehicle looking fantastic. The coating can be clayed but it should not be necessary since Opti-Coat 2.0 releases contaminants easily. Use detail sprays as desired to intensify the gloss. You can also use Optimum Poli-Seal by hand or with dual action polisher with a foam finishing pad to clean the paint over time.
      11-15-2013, 11:21 PM   #12
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Why spacers on aftermarket wheels? Is that not part of the point of going aftermarket in the first place?
      11-16-2013, 09:45 AM   #13
P1
P1's Avatar
11572
And since we're on the subject of Optimum, I have a few detailing products from them I use every time I wash the car: their Instant Detailer is my current favorite, and I really like their Opti-Bond Tire Gel also. Great products.
      11-17-2013, 02:24 PM   #14
bmw_4.8_e70
Drives: 2010 bmw x5 v8 4.8
Go with 20mm in the rear and 12 mm in the front, it will sit flush i have the same set up,
      11-17-2013, 03:46 PM   #15
denaliman
denaliman's Avatar
2013 X6M  [0.00]
I love the opti-bond tire gel.
