      11-10-2013, 01:25 PM   #1
slim
Drives: 2013 BMW X5 35i
Should I get OEM TPMS?
I am going to buy 20'' rims for my 2013 X5 and wondering if I should get OEM TPMS. I don't want to have a problem when I get my new tires/rims/tpms installed and then have the TPMS showing not working. What do you think? OEM tpms can be pretty pricey.
      11-10-2013, 05:37 PM   #2
PAX5
Drives: 2012 X5 50i
The Beru TPMS work fine (note that in January 2012 BERU System TPMS Division was sold to HUF Group Germany). BavarianX is a supplier.
Make sure that the valve neck is adjustable, in case you're buying after market wheels. The wheel profile may be different than OE.
PAX5
BMWCCA 20645
      11-11-2013, 10:54 AM   #3
overheadvalve
Drives: 2011 335I Coupe/2017 Macan
+1 on the Beru. Make sure they are current model(year). Not older pre 2010's. The system changed somewhere along the line and the older ones are not compatible with your TPMS thus throwing a dash light. The Beru's valve stem (sticks through the wheel) can be changed to accommodate various aftermarket wheels. You may need a different set of stems. The wheel company should know what works.
      11-12-2013, 02:14 PM   #4
slim
Thanks guys for the response! I saw someone on here from BavarianX selling TPMS. I will try to find his post. Thanks!
