09-24-2021, 12:33 PM | #1 |
Rep 3
Help Needed: 2011 X70 No start, no crank
Hello,
I have a 2011 X70 xDrive 35i with no start no crank with so many errors when I scan it. I noticed that Terminal 50E voltage is 6.61V. I am not sure where to start with this but I've put the errors and the voltages below. Any help is appreciated. Thanks, CAS (Car Access System) A0C1 CAS Output Terminal 50 A0C2 CAS Output, Terminal 50 RS A0B1 CAS Input, Selector Lever Position Implausible A0B3 CAS Starter Motor, Terminal 50 ABS (Anti-locking Braking System) 6F60 No Message (Electronic Transmission Control, 0x1A2), Receiver DSC, Transmitter EGS/HIM D36A No Message (VTG 0xBC), Receiver DSG, Transmitter VTG D358 No Message (Transmission 0x0BA), Receiver DSC Transmitter EGS/HIM D355 No Message (Torque 0x0A9), Receiver DSC, Transmitter DME-DDE D354 No Message (Torque 0x0A8), Receiver DSC, Transmitter DME-DDE D356 No Message (Torque 0x0AA), Receiver DSC, Transmitter DME-DDE 6F56 No Message (Engine Control 0x64). Receiver DSC EKPS (Electric Fuel Pump) CED4 No Message (0xAA), Receiver EKPS, Transmitter DME-DDE GWS (Gear Selector Switch) E094 No Message (Display Transmission Data) From the electronic transmission control receiver gear selector switch. Transmission Electronic Transmission Control/HIM Voltages/Current: Current, Terminal 50L 0.41A Voltage, Terminal 15-1 11.57V Voltage, Terminal 15-2 11.57V Voltage, Terminal 15-3 11.57V Voltage, Terminal 15, Wake Up (ACC) 0.13V Voltage, Terminal 15, Wake Up (PT CAN) 11.18V Voltage, Terminal 30E, 11.57V Voltage, Terminal 30g, 11.57V Voltage, Terminal 30L, 11.57V Voltage, Terminal 50E, 6.61V Voltage, Terminal R 11.57V |
09-27-2021, 11:53 AM | #4 |
Rep 60
Can you confirm that the ground straps are in good shape?
Location can be found in this thread... https://www.xbimmers.com/forums/show....php?t=1632755 |
09-27-2021, 01:51 PM | #5 |
Rep 132
Ground strap is a good tip..
Also, If the battery is real bad it may not start even with a jump box because the internal resistance is very high. How old is the battery? If there is a standard battery in there now, odds are the battery system wasn't told the original AGM battery was replaced with a standard battery. You have to do that if you don't replace the original battery with the exact same type. If the battery is old or original, I would start with the battery, and go from there. Maybe try a spare battery that is laying around.. |
09-28-2021, 04:52 PM | #6 | |
Rep 3
I rescanned the car again and I have a bunch of errors even after clearing them. CAS (Car Access System - CAS/FEM/BDC) A0B1 CAS: Input, selector-lever position, implausible A0C1 CAS: output, Terminal 50 A0C2 CAS: output, Terminal 50 RS EKPS (Electronic Fuel Pump) CED4 No message (0xAA), Receiver EKPS, Transmitter DME-DDE GWS (Gear Selector Switch) E094 No message (Display, Transmission Data) From the electronic transmission control receiver gear selector switch, transmitter electronic transmission control/HIM ABS 9 no message errors EPB (Electric Parking Brake - EMF) 601D EMF 601E EMF D395 no message |
