09-03-2021, 12:41 PM | #1 |
Rep 66
Help with Bimmergeeks protool
So from a previous thread, I was asking about battery replacement. I decided to get a BG protool license, a battery from autozone and do it myself. All went well on the install and registering the new battery using protool was easy.
As I had it open I wanted to look at the gauges and monitor a few things. I can connect to the vehicle fine. I can read all info, any error codes etc. The first time I went into gauges on the DME, they worked. Everything defaults to RPM but I changed one gauge to pedal position and watched as everything looked good. I then went back into setup and selected additional parameters by putting a check mark next to them. After that I went back to live data and items are there but all of the gauges are a static value. Nothing changes anymore. I tried reconnecting, unplugging, changing options. Nothing seems to work. I still have full communication with everything its just gauges are not logging. Anyone run across this before? |
09-06-2021, 08:31 AM | #2 |
Rep 66
For those interested, bimmergeeks support has been fantastic. I sent this to them as well through email on Friday of a holiday weekend and they responded within a few hours. Then followed up on Saturday and Sunday.
Ultimately it is something they have seen and are working on a fix. It has to do with the number of parameters chosen to log and not the actual item. Some pcm's seem to limit it to 8 selections. If you choose more, it locks up. Doesn't cause any issues; once you go back to 8 you're fine. |
09-07-2021, 01:08 PM | #3 |
2022 M4 Comp Xdrive
1016
Rep 1,540
Yea their support is great..I had issues in the new android build not being able to save logs. They actually went out and bought the same phone I had so that they can resolve the problem.
Their support is fantastic. |
09-10-2021, 08:57 PM | #4 | |
Rep 548
Welcome to Protool btw. It’s fun coding all these things into the car. |
