      12-30-2013, 09:58 PM   #1
nabizzy
Drives: 2018 X5M LBB
Issue
So I was driving my car around here, it is about 38 degrees F, and I had M mode on and was driving somewhat spiritedly. I came to a stop after driving around for about 45 minutes and there was steamy stuff coming from from where the kidney grills are. I had gotten a car wash just before this, so perhaps there was water getting hot, I am not sure. The car was not overheating. Chances of this being just water getting heated by the engine and turning to steam? Should I be worried?
      12-30-2013, 10:13 PM   #2
nachilus
Drives: 2007 x5 4.8
I experienced something similar, it turned out to be nothing. If you did not have a warning after your spirited drive then you should be fine.
if the same thing happen tomorrow take a look under the hood for any tell tale signs. The only issue I ever had with steam coming from my hood that was a real issue is when my expansion tank was cracked.
      12-31-2013, 12:04 PM   #3
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
I have had this happen intermittently as well, like maybe once a month. I have seen it after a 15 minute drive to work, as well as after longer drives. It doesn't seem related to weather, how hard you drive or how long. Good luck getting your dealer to diagnose.
