      07-07-2014, 11:42 AM   #1
Joyaant911
Drives: 2007 x5
Driveshaft diagnosis help
So after much time with this dreaded vibration seems like my mechanic is leaning towards the rear driveshaft U joint as I already replaced the flex joint and bearing with no luck.. Does anybody have any experience replacing a rear driveshaft u joint?
      07-07-2014, 05:51 PM   #2
mitch808
Drives: 2012 X5 35i
Do you qualify for the driveshaft recall? Does that apply to you?
      07-07-2014, 06:14 PM   #3
Joyaant911
Drives: 2007 x5
There was a driveshaft recall?? Looking into this now
      07-07-2014, 07:02 PM   #4
mitch808
Drives: 2012 X5 35i
Sorry, just looked at your profile, you have a 2007 no? It applied to newer models, 2010 ish.
http://www.xbimmers.com/forums/showt...ght=driveshaft
      07-24-2014, 07:45 PM   #5
Joyaant911
Drives: 2007 x5
Does anybody have experience with failing driveshafts?? Does the driveshaft have 2 flex joint bushings? One rear one front? If I accelerate rapidly the entire cabin center console viciously shakes and vibrates like something is broken or loose in the driveshaft. Before I start tearing it down I wanna be ready with all the parts I'll need to rebuild under there
      07-24-2014, 09:22 PM   #6
Florin350hp
Drives: 2009 48 E70
Drive shaft fail
Hi. My front driveshaft has a bad u joint with a big play. I can move it up and down with my finger. It also damaged the yoke in the transfer case. I will to buy them both.
      07-25-2014, 03:01 PM   #7
godmans
Drives: 135i / 335i / X6M
Can you pls kindly keep us posted? after paying the diagnostic fee with my dealership, they said that it is normal play with the yoke @ transfer case and that another X6 did the same too...
I dont have much vibration other than slight at the 60~65mph mark, so not sure how to look at this now.
      07-25-2014, 03:24 PM   #8
Florin350hp
Drives: 2009 48 E70
Drive shaft
I talked earlier with the mecanics and they said they removed the drive shaft and looked inside of the transfer case. That female conection( input shaft,yoke) it is damaged. Cobra transmision sells parts for the transfer case but I will replace it with a reman. Does anyone knows if above this u-joint is a drainage tube from ac or windshield? Thx
      07-25-2014, 07:45 PM   #9
godmans
thanks and good luck with finding a reman TC, good luck btw!
      07-25-2014, 09:08 PM   #10
Florin350hp
Drives: 2009 48 E70
Transfer case
At any dealer they have reman for about 2200$. Good luck to you too.
      08-01-2014, 05:31 PM   #11
Joyaant911
Drives: 2007 x5
Is the part inside the transfer case replaceable I'm seeing the same play in my front shaft I think that's my problem.. Also my flex joint which I just replaced is torn to shreds.
