03-31-2014, 06:25 PM | #1 |
Rep 92
Fog Bulb Swap on 2013
Just thought I'd let other members know it's possible to swap out in about 10 min with no tools.
Key is to carefully remove the bottom intake honeycomb grills. Then there is a little plastic trap door that closes off the back of the bulb area. Once you open the trap door you just rotate and remove. Piece of cake. No need to remove the bumper or do anything crazy like that. Joe |
03-31-2014, 07:07 PM | #2 |
Rep 994
What bulbs did you use? I'm pretty sure my passenger side is out, but there isn't a lot of consensus on what to replace it with. Some went yellow, some selective yellow, some chose an ebay special from mainland china built by 6yr olds and dipped in Mercury....
03-31-2014, 07:10 PM | #3 |
Rep 92
ebay special
http://m.ebay.com/itm?itemId=161207608706 For 15 bucks they seem to match the OEM HIDs pretty well. Joe |
03-31-2014, 08:20 PM | #6 | |
Rep 3,995
I've got these installed as well, and they look great!
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
04-01-2014, 07:48 AM | #8 |
Rep 92
I took a pic and it turned out awful
It does match pretty darn well...worth the $15 for sure. I do have an E70 and really all you need to do is what I described. No tools needed at all. Joe |
04-01-2014, 05:44 PM | #9 | |
Rep 140
