05-21-2014, 01:17 AM | #1 |
Rep 8
I searched and didn't really find any concrete information on front clearances. I know the rears will fit no problem..
I'm looking to do a square setup (so I can rotate tires) and looking at 10.5+40 all around. Looking at bmwstylewheels.com it seems my 19" 335 wheels are 19x9+48, same specs as 334 wheels, which would reduce my front inner clearance by 11mm. assuming that website is correct and I probably run a square setup right now @ 19x9+48, comparing it to stock: Front: OEM 20s 20x10+40: 5mm less inner, extends 21mm Wheel1 20x10.5+40: 10mm less inner, extends 26mm Rear: OEM 20s 20x11+37: 14mm less inner, extends 36mm Wheel1 20x10.5+40: 10mm less inner, extends 26mm (i'll probably run a 20mm spacer unless this would adversely affect towing ability...) Am I safe in the front with these wheels?? I plan to run 295/40R20 conti DWS which is also very close to stock tire/wheel diameter of 29.2" Last edited by jinhao; 05-21-2014 at 09:35 AM.. |
05-21-2014, 06:41 AM | #2 |
Rep 1,719
Drives: 2014 650xi Gran Coupe Msport
You should be fine.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
05-21-2014, 09:55 PM | #4 | |
Rep 3,995
I always thought the 223M wheels were the only staggered 19s for the E70.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
05-21-2014, 09:57 PM | #5 | |
Rep 1,719
05-21-2014, 10:08 PM | #6 |
Rep 8
sorry, i should have been more clear. I was referring to the wheels on my actual car as they look square.. so I doubt they are staggered. hub face is the same thickness and visually don't look staggered as the 223M's do....
...and a staggered setup almost always have different offsets for front and rear in addition to different widths. |
05-22-2014, 05:45 AM | #7 |
Rep 1,719
Are your tires the same size? If so the wheels aren't staggered.
05-22-2014, 12:26 PM | #8 |
Rep 8
guess you weren't really reading the thread. my wheels to my knowledge after looking at them aren't staggered. a website says they could be. you can mount that same tire on a 9 or 10" wheel.
just trying to figure out what i definitively have so my measurements are accurate. |
05-22-2014, 12:45 PM | #9 | |
Rep 1,719
05-23-2014, 05:42 AM | #10 | |
Rep 87
Harry |
