      12-22-2010, 10:13 AM   #1
coodem
Drives: M335d
DTC light flashes when going over speed bump
Wondering if any of you guys are experiencing the same issue. When I go over a large speed bump, always on the downward side, the DTC light flashes for a few seconds, then goes out, all else appears normal. Not going fast, if I go over real slow it's all fine
      12-22-2010, 10:48 AM   #2
Slalom
Slalom's Avatar
Drives: 04 Z4, 18 X3 M40i
2004 Z4  [0.00]
2018 BMW X3 M40i  [10.00]
Sounds like a loose connection - had it happen on previous car - just needed a few minutes in the shop. I was out of warranty but they did not charge.
      12-22-2010, 11:11 AM   #3
flipside99
Drives: iX M60
same thing happens to me.. Hasn't really concerned me.
      12-22-2010, 11:11 AM   #4
ryansumm
Drives: X6M 5.0D Carbon Black
Hi Mate I have this too on my 2008 3.5d, any speed bump always coming down, spoke to my service centre about this - they considered this normal.
      12-22-2010, 11:36 AM   #5
newdadkel
newdadkel's Avatar
Drives: 2011 X6M CBM
Can you feel if there is a loss of power at all? When its on, try to speed up some and see if it is just normal DSC function which will cut power if it senses loss of traction. If the power is not cut, you might have them look at the switch for loose connection but sounds normal.
      12-23-2010, 12:21 AM   #6
imposss
imposss's Avatar
Drives: M4 Comprtetion
I have the same "issue"
      12-23-2010, 12:26 AM   #7
GJM
Xdrive
GJM's Avatar
Australia
Drives: X6 35d/X5 3d
same here
gjm
      12-23-2010, 03:35 AM   #8
GeraG
Drives: X5, X6
+1
      12-30-2010, 02:03 AM   #9
E92_atl
E92_atl's Avatar
Drives: black on black 2006 335i
just hold the DTC button down for about 10 to 15secs and the DTC will shot off all the way and that light wont come back up and you will not lose any power!!!
ill do a video and post it soon.
DRIVE IT TILL YOU BREAK IT!!!
      01-01-2011, 10:18 AM   #10
STIto335
Drives: a car
This is not an "issue" most cars will do it just depends on how sensitive the traction control system is. In a GTR you go over pretty much any bump while full throttle and the car dies for a second or 2, also over speed bumps it hesitates after.
      01-01-2011, 01:28 PM   #11
csimon
Drives: 2011 X6 5.0 blk/blk OMG
same here.
      01-04-2011, 10:13 AM   #12
LLH
Drives: X6 X40D
Same happens with my x40d unless I drive over at walking pace
