      12-05-2010, 12:19 AM   #1
zerrantoss
Drives: 2011 X6
Automatic Headlamp Control
Ever since I bought the X6 several weeks ago, I have always set the headlamp setting to automatic.
Recently I noticed that my low beams are always on, regardless of the ambient brightness. It turns on even if it's running under a clear-sky sunny day. The "Automatic" Headlamp Control just doesn't seem to automatic at all..
Have you guys run into this kind of problem? Is it possible that I have a broken light sensor? Where is the sensor located?
Thanks in advance for answering!
      12-05-2010, 05:21 AM   #2
jouzef2
Drives: x6 5.0i
No, i think it's normal ..
cuz me also when i put the light in automatic mode, & when the light is on (in the night) , and when it became morning , the light still on & did not switch off regardless of the ambient brightness , i think the sensor is not quite enough sensitive
      12-05-2010, 12:51 PM   #3
Ikendiken
Ikendiken's Avatar
Drives: '13 E92 M3
I think the sensor is "sticky" on. What I notice is that when driving before the sun rises, the lights remain on even after it has become quiet bright outside. But if I park the car, the lights are off when I start back up.
Also they kick on pretty quick when driving into a garage, for instance, but delay a bit turning back off when leaving the garage.
      12-05-2010, 06:55 PM   #4
bobbydog
Drives: E90 M3
In Canada is the law to have day time running lights...It's not required in the US so if Canadians import a car from the US it will have to be fitted with day time running lights.
So it's normal in Canada!
      12-06-2010, 12:22 AM   #5
GeraG
Drives: X5, X6
Have you checked your day lights setting in the "vehicle setting" menu? It may well be that your day time lights are set to “on”.
      12-06-2010, 10:41 AM   #6
zerrantoss
Drives: 2011 X6
Yes, in Canada it is the law to have day time running lights. However, the DRL are the 4 rings of angel eyes, not the HID low beam. My problem is that the low beams are constantly on even in the sunlight
      12-06-2010, 12:18 PM   #7
Sunstreaker
Drives: X6 35D
Get the BMW dealer to change the sensitivity, I told them the problem and they fixed it within the hour of booking it in.
      12-06-2010, 12:27 PM   #8
zerrantoss
Drives: 2011 X6
Thanks. I will bring it in for the adjustment.
      12-10-2010, 10:06 AM   #9
zerrantoss
Drives: 2011 X6
I brought the car to the dealer yesterday. The mechanic told me that he couldn't do anything. There is no way to adjust or calibrate the sensor's sensitivity...
He said that I will have to manually turn the knob if I don't want the headlights on.
According to your solution, I think he is BSing me...
      12-11-2010, 03:17 AM   #10
X6 MBN
X6 MBN's Avatar
Drives: M5
Yes he is, lots of people on this forum have had the sensitivity adjusted.
