      11-26-2010, 01:47 PM   #1
looch57
looch57's Avatar
Drives: 2011 X6
2011 X6 Sports Package
Just purchased a 2011 x6 3.5i with sports package added including the 20" y spoke wheels. Wanted to know if the suspension is the same as the basic 3.5i X6. Thanks!
...Sports Package in depth details would be great!
      11-26-2010, 01:57 PM   #2
kgclark
Drives: '11 X6 35i VR/Oyster
No. Sports package includes adaptive drive- much better than the base suspension.
      11-26-2010, 04:21 PM   #3
looch57
looch57's Avatar
Drives: 2011 X6
Sounds good thanks!
      11-27-2010, 11:33 PM   #4
imposss
imposss's Avatar
Drives: M4 Comprtetion
I have sport package but don't have adaptive drive, maybe earlier models doesn't have ad.
      11-28-2010, 07:29 AM   #5
aci72
Drives: X6 5.0
Actually there are two options: 1) sport activity package (without adaptive drive,but simply 20" wheels set up) and 2) sport package which also include adaptive drive...this one is more expensive...
      11-28-2010, 10:53 AM   #6
coachk101
coachk101's Avatar
Drives: 2009 X6
I have 09 X6 35i.
Mine has a sports package....and I can push the SPORT button inside by my toggle.....seems it's a bit quicker when I do and it handles better around curves etc.
Can anyone else elaborate on this as well?
      11-28-2010, 11:27 AM   #7
Rac10000
Drives: 981 Cayman S
Originally Posted by coachk101 View Post
I have 09 X6 35i.
1) Pushing the "sport" button below the gear shifter = Sport setting for Adaptive Drive. This button only controls the settings for the EDC (Electronic Dampening Control) and Active Roll Stabilization. It does not have anything to do with the engine, throttle mapping, or transmission. It will handle better/flatter with this sport mode engaged. The ride is a little harsher though. Great for some back-road fun ... not so great for the interstate.
**You only have this button if you ordered the Sport Package (NOT Sport Activity Package) or Adaptive Drive as a stand alone option.**
2) Pushing the gear selector to the left = Drive Sport = Sport setting for the transmission. The center display in-between the speedometer and tachometer will show the current gear as S1, S2, S3, etc. It will hold a lower gear and will hold it for longer. The car will feel more responsive.
3) Pushing the gear selector to the left and then pushing it forward or back and/or using the steering wheel paddles = Drive Sport - Manual Mode. The center display in-between the speedometer and tachometer will show the current gear as M1, M2, M3, etc.
2024 BMW X7 M60i - Ordered!
      11-28-2010, 11:42 AM   #8
coachk101
coachk101's Avatar
Drives: 2009 X6
Originally Posted by Rac10000 View Post
1) Pushing the "sport" below the gear shifter = Sport setting for Adaptive Drive. This button only controls the settings for the EDC (Electronic Dampening Control) and Active Roll Stabilization. It does not have anything to do with the engine, throttle mapping, or transmission. It will handle better/flatter with this sport mode engaged. The ride is a little harsher though. Great for some back-road fun ... not so great for the interstate.
Excellent!! Thanks!!
      11-28-2010, 11:45 AM   #9
Rac10000
No problem!
      11-28-2010, 12:08 PM   #10
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
So if you have the Sport button, you have adaptive drive? Is that the tell take sign?
2011 535i
2008 VW GTI
      11-28-2010, 12:26 PM   #11
Rac10000
Yes, sir.
I found this pic on google images ... you can see the sport button right below the shifter ... in front of the parking break ...
      11-28-2010, 05:27 PM   #12
Ikendiken
Ikendiken's Avatar
Drives: '13 E92 M3
I keep adaptive drive in sport mode almost all the time. Its slightly harsher ride, but not much. Its not uncomfortable at all. No one has mentioned the ride except to comment how stable it seems in corners.
I flip between sport (S#) and standard (D) shift mode several times in a typical drive. Any time I need more aggressive acceleration, like merging into traffic or passing, I move into sport shift mode. It gives the X6 a totally different personality. MWHAHAHA
      11-29-2010, 02:38 PM   #13
looch57
looch57's Avatar
Drives: 2011 X6
Yes, sir.
I don't have that sport button underneath my shifter, does this mean I do not have Adaptive Drive?
      11-29-2010, 04:44 PM   #14
Ikendiken
Ikendiken's Avatar
Drives: '13 E92 M3
Yes, you do not have Adaptive Drive.
      11-29-2010, 04:49 PM   #15
looch57
looch57's Avatar
Drives: 2011 X6
I see. I double checked and I only have the Sports Activity Package which does not include Adaptive Drive. thanks for helping me clear that up.
