03-24-2016, 02:35 PM | #1 |
Rep 2,009
Wireless router recommendation
I need a recommendation for a high performance wireless router that's not necessarily going to break the bank. Doesnt need to have a ton of ports for the hardwired stuff but needs to be reliable. Single band is perfectly fine. It's just been ages since I've even looked at this stuff so I would appreciate some insight on the latest tech.
My current one lost the wireless capability... started noticing the wireless speeds dropping from 80mbps to 10 over past month. While my hardwired lines stayed constant at 150mbps. |
03-24-2016, 07:29 PM | #2 |
Rep 3,241
Probably the radio in the wireless router is starting to degrade and will eventually fail.
You'll definitely want to have dual band capability. More specifically, you'll want to have 5 GHz capability as there are more available channels and less interference (currently) which will translate into more reliable connections and better performance. In the SOHO arena of wireless routers, many of them are pretty much the same. The ones which tend to get a decent following are Linksys, Asus, and Netgear. I can't recommend one personally to you as I haven't looked at SOHO class equipment for many years. I've moved on to business class equipment for my home network. A good place to check out reviews on SOHO wireless routers is http://www.smallnetbuilder.com/ |
03-24-2016, 07:40 PM | #3 |
Rep 4,531
I run an ASUS RT-N56U
http://www.amazon.com/Asus-Dual-Band...s=asus+rt-n56u Maintain my 50/5 for a year now (how long I've hard it) wirelessly. Never dropped out on it, never had to reset it. |
03-25-2016, 01:31 PM | #5 |
Rep 774
Drives: E90 335i & E60 550i
Check out the Ubiquity UAP-AC-PRO. It is a wireless access point. They don't make routers with built in wireless but you can just run this AP separately. Great performance, management interface, and bang for the buck.
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
03-25-2016, 09:59 PM | #7 |
Rep 2,009
Thanks guys. That Asus router seems to have good reviews and is priced well. I never thought about them in the networking segment. I've always viewed them as a mobo maker.
03-25-2016, 10:37 PM | #8 |
Rep 945
I'll throw my hat in the ring for the ASUS routers too. Lightning hit in the neighborhood cooked my RT-N56U. Currently, I'm rocking an RT-AC68U. Superb range for both, great reliability, and very user-friendly firmware
09-26-2016, 01:05 PM | #10 |
Rep 11,843
Drives: MY24 G01 AW Msport
i do need to upgrade my router.. i may go with Linksys - AC2600 Dual-Band Wi-Fi Router
09-26-2016, 01:18 PM | #11 | |
Rep 5,506
I'm running the Airport Extreme. Very reliable and haven't had any problems. I used to go through a router every 2-3 years before. The routers run hot and the wireless performance degrades over time. I've noticed the Apple runs cool and has a active fan inside.
Auto Detailing Enthusiast!
09-26-2016, 01:27 PM | #12 |
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
Asus ftw.
Currently running this with 0 issues. https://www.amazon.com/RT-N66U-Dual-.../dp/B006QB1RPY Also a tip: Routers get killed from heat. They are small computers afterall. Be sure not to place it ontop of or underneath your modem.
09-26-2016, 01:28 PM | #13 |
Rep 3,465
Drives: 997.2 GT3, '17 G30
I have 53 of these deployed all over my office building along with UAP-LR's and they are fantastic. 2 years going strong and not one device has failed yet.
ig: 0verrev
09-26-2016, 02:24 PM | #14 |
Rep 3,395
If you dont care about security then most any best buy linksys/similar will do
If you DO care about security then you should be looking at something like the SOHO solutions from Check Point, SonicWall or similar. You will spend more but you actually get a next gen FW with actual security |
