01-03-2014, 11:39 AM | #1 |
Rep 207
Drives: 2012 X5M
Garage List 2013 Toyota Pruis 3 [0.00]
2006 Porsche Cayenne S [0.00] 2012 BMW X5M [7.66] 2002 Ferrari 360 sp ... [0.00] 1999 Porsche 911 Ca ... [0.00] 2000 BMW 328i [0.00] |
Break squealing
Anyone ever have break squealing problem?
01-03-2014, 03:19 PM | #2 |
Rep 1
YES!!! Had it with my 08 4.8 X5. Was told by service manager a little squeaking was normal?
Now have it with my 10 X5M. Was told same thing. They said it is the sensor on the brake pad. Its getting louder and louder. I hope someone has a solution |
01-03-2014, 08:20 PM | #3 |
Rep 691
It is a normal "issue" with these cars. Part of having high performance brakes mean they will squeal like pig's in the cold. My b8 s4 does the same but not nearly as obnoxiously as the M does. I actually just had my pads replaced because the squeal was beyond obnoxious and embarrassing especially when people don't know about cars and just think somethings wrong with my 100k truck. Got 28k miles out of those pads. It helps to bed the brakes (its winter now so not the best time to do this, but I found 2-3 consecutive hard stops from high speed ~120 to 20 helped get rid of the noise for a while. I mainly hear it when I'm backing out of the garage slowly now, used to happen when creeping to a stop as well but not anymore (again only when it is very cold).
2012 X5M Monte Carlo Blue/Black-SOLD
Velos Stage 2/Velos Catless downpipes/Dinan exhaust/Dinan Suspension 2018 M6 Gran Coupe Competition- Singapore Grey/Aragon Brown DME Stage 3 |
01-03-2014, 08:27 PM | #4 |
Rep 399
No brake pad squeak here. If the sensors were touching the rotors you would have a brake pad warning light come on. Akebono euro ceramic pads are what i used. Good luck.
01-03-2014, 08:36 PM | #5 |
Rep 3,995
When I had my M3, I had it in the dealer for this exact same thing, and in the end the final word was that M brakes are always going to have some noise (he casually mentioned the X5M brakes were the noisiest of them all).
One thing I found was that the harder you use the brakes, the quieter they get. For me, a few romps around town and hard braking at stop lights got them much, much quieter. I guess they're made to be used.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
01-03-2014, 09:21 PM | #6 |
Rep 377
On my 2012 X5M I am about to hit 31K with the original pads and have minimal at most issues with any brake noise. Every once and a while I hear a faint squeal when backing into the garage but nothing much at all.
01-04-2014, 08:47 PM | #7 |
Rep 25
I just had my rear pads replaced yesterday due to squeaking bad in reverse. At first when I scheduled I got the same song and dance it is normal for them to squeak a little. So I asked, I have been driving this car for a year and a half with no noise, so was that abnormal. Brought it in and they replaced them.
When I left the shop they squeeked louder and I brought it back and the guy told me to stomp on them hard and it will stop. Well I did and it stopped. Not sure why rears went bad before the fronts?? |
01-05-2014, 05:40 PM | #9 |
Rep 75
Definitely not the sensor. It relates to the pad formulation generally. If it is intermittent it could be temperature related (cold). The pads could be worn out, maybe uneven wear.
Generally the standard OE formulation is quieter mainly because hundreds of hours would have been spent trying to make it quiet. Not always successful. |
01-06-2014, 09:07 AM | #10 |
Rep 207
Drives: 2012 X5M
My brakes were nice and quiet until recently 30K+ miles. Don't make noise when cold or backing up, only once it warmed up. The squeal comes when the brakes are used lightly coming to a stop, don't make noise when stomped on hard. Just very annoying.
01-06-2014, 10:52 PM | #11 |
Rep 75
30K miles is 48K Km's. Definitely possible that they are near the end. I changed mine at 50K km's (because the screen said so) but admittedly they had another 10K km's or more on inspection when they were taken out.
03-25-2014, 02:06 PM | #12 |
Rep 207
Drives: 2012 X5M
Problem solved!
The squealing noise was driving me crazy. Noise free brake squeal from Bavarian autosport. $9.95. Applied to the back of the pads and the piston. Noise free now, it's amazing! I tried several brake squealing compound prior but didn't help, the Noise free really works!!! |
03-26-2014, 12:08 AM | #13 |
Rep 175
thank you for the solution, i have the same problem and planned to get a set of new brake pad even the service time still show 7000miles.
but i will give a try for that Noise free brake squeal. |
03-26-2014, 12:33 PM | #14 |
Rep 691
Hmm looks like I'll be buying a bottle, thanks for sharing
03-27-2014, 01:54 PM | #15 |
German Performance Addict
Rep 26
This thread has brought back my sanity. Thought I was doing something wrong. Just hit 31k miles. Been doing this since I got the car at 25k.
2010 X5M - Silverstone Metallic - Velos Tune - Eisenmann Race Exhaust (Black) - 102mm Tips - Paint-matched Reflectors (F&R) - Gloss Black Performance Grille and Side Indicators - Black Dipped Wheels - Full LED Interior Lighting - Custom X5M rubber mats
