03-07-2016, 08:28 PM | #1 |
Rep 234
M4 carbon fiber strut brace and other stiffening parts on F32 4 series !!
Featured on BIMMERPOST.com Stage 1 M4 Support bearing reinforcement ring Stage 2 M4 Alloy center strut brace + M4 support bearing Stage 3 M4 Carbon (CFRP) strut front end Stage 4 M4 Extension suspension cross brace + Diagonal strut My 2014 428i (N26) already has Ohlins R&T MP00 suspension and M4 genuine 437M wheel + PSS 235 / 265 tire. Currently Stage 3 completed .. Enjoy !! Here we go : Both Beinforcement ring and Guide support bearing need to be matched with production year of yours. from 2015 it's changed from M10 3 hole to M8 5 hole. Stage 1 M4 Reinforcement ring for Guide support bearing ~ 2014 : used M10 x 3 hole Reinforcement ring, left : 31302285700 Reinforcement ring, Right : 31302285701 Hex screw M10 6 EA : 07119904141 2015 ~ : used M8 x 5 hole Reinforcement ring, left : 31302361991 Reinforcement ring, Right : 31302361992 Hex screw M8 10 EA : 31307855400 Stage 2 M4 Alloy center strut brace + M4 support bearing ~ 2014 : used M10 x 3 hole Guide Support bearing 2EA : 3130284702 Alloy Strut brace (left steering) 1EA : 31122284855 2015 ~ : used M8 x 5 hole Guide Support bearing 2EA : 31307853702 Alloy Strut brace (left steering) 1EA : 31127855855 Torx bolt M10 (alloy SB - top) 56Nm 2EA : 31106854219 Torx bolt M8 (alloy SB - mount) 28Nm 6EA : 31106859809 Fillister head screw M10 (alloy SB - edge) 34Nm 2EA : 07147162464 Blind rivet nut, flat headed 2EA : 51718065070 Cover, windsheild panel, Left : 51718059699 Cover, windsheild panel, Right : 64318059697 Engine hood sealing, Left : 51768058561 Engine hood sealing, Right : 51768058562 Expanding rivet 6EA : 51118174185 Stage 3 M4 Carbon (CFRP) strut front end CFRP strut front end 1EA : 51618061631 Cross link (only Coupe & Sedan) 1EA : 51647294928 Hex bolt M8 (CFRP - front) 28Nm 2EA : 22326760945 Hex bolt M8 (CFRP inside) 28Nm 6EA : 11287839136 Stage 4 M4 Extension suspension cross brace + Diagonal strut Extension Strut Tower, Left : 31122284857 Extension Strut Tower, Right : 31122284858 Link, Left : 31122284859 Link, Right : 31122284860 Torx bolt M8 2EA : 07147248303 Bottom reinforcement option only for sedan, coupe (Convertible already installed) Stiffening plate 1EA : 51617299690 Torx bolt M10 2EA : 07147313416 Diagonal Strut 1EA : 51647294929 Adapter plate 1EA : 51647311426 Tort bolt M10 2EA : 07146959643 Hex bolt M8 4EA : 07147321202 No.1 BMW tuning forum www.bimmerwerks.co.kr Last edited by Steve_Jr; 11-22-2016 at 11:52 PM.. |
28
Dr Thrillride1398.50 ABPReader215.00 BMWFreaky63.50 ando2002.00 HKMP7244.00 moonriver19.00 Dog Face Pony Soldier9719.50 david51537.50 Blueeyesredpanda400.50 cdwalls702.00 ELiTeNeSs196.50 chet8227.50 Fr3sh29.50 steveindabmer47.50 disintegrator66412.50 leo.jensen10.00 DLag30103.50 Tommi_Mav65.50 IcewaterPete2145.00 |
03-08-2016, 02:19 AM | #4 |
Schmollbraten
12512
Rep 1,985
Nice upgrade, cool pictures. Any more deeper purposes than optical reasons? Surely not the weight, or?
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
lawgone63.50 |
03-08-2016, 03:36 AM | #5 | |
Rep 234
Defintely it is not dress up item, anyone even you cannot see anything when you park or drive. M4 9J wheel gave several benefits to me for sheer driving but also gave more pressure to Ohlins suspension. Total 40mm + track distance increase between each front wheel needs stronger spring. I felt spring rate diffference a lot. it's getting softer than a case of with standard offset wheel. (damper setting as well) Last edited by Steve_Jr; 03-08-2016 at 03:49 AM.. |
03-08-2016, 07:56 AM | #6 |
Rep 410
Drives: One car with good steering ;)
Would you have the part numbers for the braces and the hardware? I'd be interested in maybe doing this in the future myself.
03-08-2016, 08:47 AM | #7 | |
Rep 234
Stage 1 M4 Reinforcement ring for Guide support bearing ~ 2014 : used M10 x 3 hole Reinforcement ring, left : 31302285700 Reinforcement ring, Right : 31302285701 Hex screw M10 6 EA : 07119904141 2015 ~ : used M8 x 5 hole Reinforcement ring, left : 31302361991 Reinforcement ring, Right : 31302361992 Hex screw M8 10 EA : 31307855400 Stage 2 M4 Alloy center strut brace + M4 support bearing ~ 2014 : used M10 x 3 hole Guide Support bearing 2EA : 3130284702 Alloy Strut brace (left steering) 1EA : 31122284855 2015 ~ : used M8 x 5 hole Guide Support bearing 2EA : 31307853702 Alloy Strut brace (left steering) 1EA : 31127855855 Torx bolt M10 (alloy SB - top) 56Nm 2EA : 31106854219 Torx bolt M8 (alloy SB - mount) 28Nm 6EA : 31106859809 Fillister head screw M10 (alloy SB - edge) 34Nm 2EA : 07147162464 Blind rivet nut, flat headed 2EA : 51718065070 Cover, windsheild panel, Left : 51718059699 Cover, windsheild panel, Right : 64318059697 Engine hood sealing, Left : 51768058561 Engine hood sealing, Right : 51768058562 Expanding rivet 6EA : 51118174185 Stage 3 M4 Carbon (CFRP) strut front end CFRP strut front end 1EA : 51618061631 Cross link (only Coupe & Sedan) 1EA : 51647294928 Hex bolt M8 (CFRP - front) 28Nm 2EA : 22326760945 Hex bolt M8 (CFRP inside) 28Nm 6EA : 11287839136 Stage 4 M4 Extension suspension cross brace + Diagonal strut Extension Strut Tower, Left : 31122284857 Extension Strut Tower, Right : 31122284858 Link, Left : 31122284859 Link, Right : 31122284860 Torx bolt M8 2EA : 07147248303 Bottom reinforcement option only for sedan, coupe (Convertible already installed) Stiffening plate 1EA : 51617299690 Torx bolt M10 2EA : 07147313416 Diagonal Strut 1EA : 51647294929 Adapter plate 1EA : 51647311426 Tort bolt M10 2EA : 07146959643 Hex bolt M8 4EA : 07147321202 Last edited by Steve_Jr; 03-17-2016 at 07:22 PM.. |
03-08-2016, 10:47 AM | #8 |
Rep 410
Awesome, hope this thread gets more attention since I'm sure that many people would like to know about how to integrate the M4 front suspension bracing. I know that I'd rather do this than simply get a strut tower brace.
Thanks OP! |
03-08-2016, 11:31 AM | #9 |
Rep 2,036
This conversion/addition did not look cheap .......$$$$$?
CFRP strut front end alone....https://www.turnermotorsport.com/p-1...uine-bmw-part/
AtlantaDude128.00 |
03-08-2016, 12:31 PM | #11 |
BimmerPost Supporting Vendor
24198
Rep 190,807
Nice!!
Wondering how much it cost
03-08-2016, 06:17 PM | #13 | |
Rep 234
https://www.ecstuning.com/Search/Sit...631/ES2767810/ That's the reason why I separated the stage ... roughly Stage 1 : $200 Stage 2 : $700 Stage 3 : $1,400 |
Fr3sh29.50 |
03-08-2016, 08:55 PM | #15 |
Rep 234
Torgue information (from BMW ISTA/P)
allthatisntnow377.00 |
03-09-2016, 12:16 AM | #16 |
2040
Rep 25,989
Wow! That looks great! Nice work!
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
03-09-2016, 11:09 PM | #20 |
Rep 234
03-10-2016, 12:47 AM | #21 | |
Rep 37
F30 330i LCI B48
Can I Install This into my F30 LCI B48 engine?
handsomdave190.00 |
03-10-2016, 04:33 AM | #22 |
Rep 234
If B48 engine has below layout , you should think changing intake box. The box looks a little bit high ...
