12-01-2017, 11:55 PM | #1 |
Rep 88
Anyone use Amsoil ATF for their transmission?
I've been searching and i can't seem to find much info.
Is there anyone using Amsoil ATF for their transmissions in their X5's? If so, which did you use and how do you like it? I'm about to order some motor oil and differential fluid from Amsoil and figured i'd use their ATF if its good to use. I have the tranny filter and gasket as well as the oil filter canister tool. Ordered a hand pump so i'm getting close to being ready.
2013 X5 50i-M Sport w/ Dinan Stg 2 tune
12-02-2017, 09:20 PM | #3 |
Mporium BMW
3751
Rep 2,907
Drives: 2011 E93 M3
12-04-2017, 04:36 PM | #4 |
Rep 1,623
I have ran amsoil atf in my 335d and 35d X5. I’ve also ran petosin and the zf fluid. I did not notice anything between the them.
As long as it meets shell m-1375.4 you should be fine. This is what I’ve used and it meets the M 1375.4 requirements. https://www.amsoil.com/shop/by-produ...?code=ATLQT-EA |
12-05-2017, 04:52 PM | #5 | |
Rep 88
12-05-2017, 06:20 PM | #6 | |
Rep 1,623
I have over 202k now. I ran Amsoil for one interval in my X5, probably 45-50k miles and currently have it in my 335d. My cars have the 6 speed. lifeguard 6 and lifeguard 8 are bottled for each tranny but, not sure how different they are or their compatibility.
No I have not run Amsoil in the engine. I run Rotella T6 and Archoil 9100. Quote:
05-17-2019, 03:11 PM | #7 |
Rep 203
Yes. Trans, differentials, and crankcase have the Amsoil in the X5D. Its BMW and ZF approved. Virgin sample test and compare with OE fluid. You won't go back.
Transfer case in the X5D runs OE fluid. Nothing compatible. Been on Amsoil since 38k in 2014 on this X5D. Now at 110k, and about to swap pan filters and refill again. We've ran Amsoil Signature ATF on several euro/GM ZF applications, as well as the X5D for a decade. Never an issue. |
