12-10-2018, 08:44 AM | #1 |
Rep 7
Glow Plug 6 Control Circuit High - CEL P067F
I'm new to this forum. I bought a used 2011 X5D with 80K earlier this year. The X5 is in great condition and hasn't given us any issues until the CEL came on.
My code reader shows the following code: P067F, Glow Plug 6 Control Circuit High I've had many BMWs (a GS1200 Adv, 2002, '88 M3, and a '97 M3), but this is my first diesel. Google searching did not reveal much info on the code P067F, nor did a search of this forum. Anyone with diesel experience/advice would be appreciated. Thanks, TRB |
12-10-2018, 10:23 AM | #2 | |
Rep 1,252
4A1F - P067F Information saved in DDE Fault code 4A1F - P067F Fault text DDE: Glow control unit: Glow control unit, output stage, cylinder 6, faulty Fault description The preheating control module detects a defective output stage for activation of the glow plug at cyl. no. 6. Condition for fault identification Test condition: The LIN message is transmitted every 500 ms. Voltage condition: The LIN message is transmitted every 500 ms. Condition for fault memory entry Debounce (1200 ms) Action in service Replace glow-plug preheating control module. Replace glow plug 1. Fault effect and breakdown warning Poor starting at low temperatures. Proceed to the nearest BMW Service facility. Driver information Warning light: MIL Service instruction Remove glow plugs with engine warmed to normal operating temperature to avoid damage to the cylinder head. © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions RELATED TSB ON GLOW PLUGS: SI B13 12 10 Fuel Systems January 2011 Technical Service This Service Information bulletin supersedes SI B13 12 10 dated December 2010. [NEW] designates changes to this revision SUBJECT Various Glow Plug and Glow Plug Control Unit Faults Stored in DDE MODEL E90, E70 with M57Y engines [NEW] SITUATION The vehicle may exhibit a long crank or rough idle in colder ambient temperatures. The Service Engine Soon lamp is on. One or more of the following faults can be stored in the DDE: ^ 4A1F combustion preheating control unit output stage cylinder 1 faulty ^ 4A2F combustion preheating control unit output stage cylinder 2 faulty ^ 4A3F combustion preheating control unit output stage cylinder 3 faulty ^ 4A4F combustion preheating control unit output stage cylinder 4 faulty ^ 4A5F combustion preheating control unit output stage cylinder 5 faulty ^ 4A6F combustion preheating control unit output stage cylinder 6 faulty ^ 494A combustion preheating control unit, diagnostic feedback CAUSE Internal fault with the glow plug control unit CORRECTION If one or more of the above faults are stored, replace the glow plug control unit and all six glow plugs. Refer to Repair Instructions REP12 21 520 (glow plug control unit) and REP12 23 505 (glow plugs) for component replacement. PARTS INFORMATION WARRANTY INFORMATION © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions |
12-10-2018, 11:31 AM | #4 | |
Rep 1,252
check out this link, post #7 has a cool pic that shows kind of what's going on I would think. https://xoutpost.com/bmw-sav-forums/...4bdc-4a14.html |
