12-06-2018, 12:32 PM | #1 |
Rep 828
Battery Load Test Using Remote Terminals?
As the title states, can I accurately load test my battery using the remote terminals under the hood instead of directly connecting to the battery?
12-06-2018, 12:40 PM | #2 |
Rep 1,252
12-06-2018, 01:17 PM | #3 |
Rep 828
Thank you, sir. It’s been a while since I’ve looked at the battery anyway, so I guess that’s that.
12-09-2018, 02:13 PM | #4 | |
Rep 7,488
The IBS is constantly checking the battery. If it is low, and then all of a sudden there's a change in its specs (due to direct charging that bypasses the IBS)...then it will detect this as an error and can cause the charging of the battery to be incorrect. The TIS gives more specifics as to why you should charge from the remote terminals in the engine bay vs charging directly to the battery. For instance, if you click this following link about the IBS...scroll down to the paragraph that says "NOTICE! CHARGING AND TRICKLE CHARGING OF THE BATTERY and you'll see it clearly states to charge from the remote engine bay location if the battery is hooked up to the vehicle: https://www.newtis.info/tisv2/a/en/e...supply/XlIbeSm And here's another link to the TIS that explains how to charge the battery when it's still connected: https://www.newtis.info/tisv2/a/en/e...der/1VnYofmbZo See the LAST sentence in the FIRST paragraph at this link in regards to charging the battery when you have an IBS: https://www.newtis.info/tisv2/a/en/e...older/1LyvW9MF
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-09-2018 at 02:49 PM.. |
12-09-2018, 05:39 PM | #5 |
Rep 828
It doesn’t appear to specify which location to use for load testing.
12-09-2018, 07:32 PM | #6 | ||
Rep 1,252
