08-12-2016, 04:35 PM | #1 |
Joint Chiefs of Staff
24330
Rep 191,065
10% OFF Evolution Racewerks Z4 Charge Pipes + Free Shipping
http://www.extremepowerhouse.com
Why shop with us? Financing: We offer 6 months no interest financing. Get the products now, pay later. You can at anytime pay the full amount or make partial payments during these 6 months. If after 6 months, you still have balance remaining on your account there will be a minimum monthly payment with interest applied, subject to credit approval. Customer Service: We offer the best customer service, period! Don’t take our word for it, check out what our customers have to say about Extreme Power House https://www.x-ph.com/customer-reviews/ Hours: We are open 7 days a week from 8 AM to 11 PM Pacific Time. Contact us: For any questions you can pm / email Mike@x-ph.com or call 725-221-5267. If you contact us during business hours, expect a reply within the hour. If you contact us outside of the regular business hours, expect a reply within 6 hours. Chat: Looking for an immediate response to your questions? Go to our website www.x-ph.com and use our chat functionality. Payments: You can make a purchase directly on our website www.x-ph.com or give us a call at 725-221-5267 and we can process your order over the phone. Shipping: Expect to get a tracking number from us same day of your order completion. We try our best to get the products delivered to you ASAP. We ship items using USPS, UPS and FedEx. Contact Mike@x-ph.com for expedited shipping options. Inventory: We stock all the popular products at our Las Vegas warehouse. If item is not in stock, we will get it drop shipped to you directly from the manufacturer’s location. XPH Rewards: We now offer Extreme Power House loyalty points to all our loyal customers. Earn 1 point after every $1 you spend with us. Earn more by sharing our website on social media and referring your friends. Newsletter: Join our newsletter for the latest XPH news, exclusive deals, group buys and coupon codes. We also offer exclusive newsletter flash sales. 10% OFF + Free Shipping! Order Link: https://www.x-ph.com/evolution-racewerks-z4-n54-3-0tt-diverter-valve-charge-pipe/ Key Features:
Again, another parts development directly from our 135i Time Attack racing program. The factory diverter valves were causing an issue of not being able to hold up against the rigors of high boost application, therefore they needed to be replaced. Thus attention was brough to the factory diverter valve pipe and the need to optimize for maximum performance on a race car facilitated the need for a new pipe to be built. Often ignored, charged intake airflow characteristics greatly affect throttle response, turbo lag and ultimately maximum power potential. Smooth bends and minimal obstructions are ideal. This is not the case with the factory diverter valve charge pipe. On the factory diverter valve chargepipe features a sound baffle for the diverter valves. This sound baffle is connected on the side of the factory diverter valve charge pipe which splits airflow. This causes turbulence inside the pipe which slows the charge intake air velocity (speed of the air traveling inside the pipe). By removing this turbulence (by eliminating the factory diverter valve sound baffle), increased throttle response, decrease turbo lag and ultimately higher maximum power potential can be realized. Our Diverter Valve Charge Pipe eliminates this sound baffle and thus eliminating the unneccesary turbulence in the diverter valve pipe, keeping charge intake air velocity at it's maximum. Apparrently, BMW thought the same thing as later model (2009-10) did not come with this baffle. Since one of the reasons for changing out the factory diverter valves was to prevent boost leaks (from prematurely opening on high boost), causing boost leaks while upgrading the diverter valve would be counterproductive. During our research and development, the connection at the throttle body was looked over very carefully. The factory diverter valve is connected to the throttle body using an o-ring inside the throttle body flange which is locked in place by a c-clip, which works very well. It also make removal/installation quick and easy. Our testing had shown it could hold quite a bit of boost. During our testing, we had pressure tested this connection up to 25 PSI. The reason why we stopped at 25 PSI was because at 25 PSI, one of the intake pipes on the turbo blew off and we could not test any higher. Hoewver, we were confident that it would easily hold over 25 PSI as the throttle body flange showed no signs of failing. Also, keep in mind, this type of connection is used throughout the engine, in many crutial areas like the coolant radiator system as well as the clutch system. If BMW did not believe in the durability of this type of connection, they would not use it in such important areas. Many of our competitors use a silicone hose connection for the throttle body connection. It is not designed for a silicone hose connection which is used by all the other brand diverter valve pipe upgrades in the market. The throttle body lip is too short and there are no "beads" to prevent the silicone hose from blowing off under boost. Even though it is the easiest way to "rig" together, it is not ideal. The best way to connect the new diverter valve pipe to the throttle body is to replicate the same connection which we did. We spent a lot of resources developing and manufacturing this factory style connection for this reason. Precision CNC machined throttle body flange ensures boost leak free connection The same issue came with the MAP sensor. The MAP sensor seals to the factory diverter valve pipe via a o-ring on the sensor itself. Having a hole in a silicone hose will definitely cause a boost leak as it will not properly seal. Therefore, again we CNC machined our own replica MAP sensor flange that utilizes the same factory o-ring seal. Precision CNC Machined MAP Sensor Flange ensures boost leak free connection MAP Sensor attached to the flange. Charge Pipe Finishes: The Diverter Valve Charge Pipe is available in the same 2 finish options as our intercoolers. It is available in a mirror polish finish. It is also available in our Type III Hard Black Anodizing for the guys that want the stealthy, factory look. An added benefit of the Type III Hard Black Anodizing is that it hardens the aluminum piping and makes it more durable against accidental damage (like dropping the pipe). We also offer our Diverter Valve Charge Pipe in any anodizing color of the rainbow you want (special order) and is available in only Type II Anodizing (asthetics). It is available as a special order item and is not stock. Brush (or plain) finish is also available. 1/8" NPT Bungs (For Methanol or Nitrous Injectors): With the popularity of methanol injection systems and nitrous systems, we have added the option of having a 1/8" NPT threaded bung (for methanol or nos injectors) welded to our diverter valve charge pipe. This allows quick and easy installation of methanol/nitrous injectors that are used in methanol injection systems and nitrous systems. You have the option of adding 1 or 2 injector bungs. Each 1/8" NPT bung will come with a plug so that you can run with or without the methanol injector. This is perfect for those who do not have the Methanol Injection yet but plan to do so in the future.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 01-08-2018 at 12:07 PM.. |
08-23-2016, 01:20 PM | #2 |
24330
Rep 191,065
BUMP!
09-09-2016, 08:32 PM | #3 |
24330
Rep 191,065
bump
09-20-2016, 04:25 PM | #4 |
24330
Rep 191,065
Bump!
www.ExtremePowerHouse.com
09-26-2016, 07:29 PM | #5 |
24330
Rep 191,065
Bump!
10-04-2016, 11:10 PM | #6 |
24330
Rep 191,065
bump
10-12-2016, 08:35 PM | #7 |
24330
Rep 191,065
Bump!
10-19-2016, 10:34 PM | #8 |
24330
Rep 191,065
Bump!
10-26-2016, 06:33 PM | #9 |
24330
Rep 191,065
Bump!
11-02-2016, 09:24 PM | #10 |
24330
Rep 191,065
bump!
11-10-2016, 10:18 PM | #11 |
24330
Rep 191,065
bump
11-18-2016, 12:30 PM | #12 |
24330
Rep 191,065
bump!
11-20-2016, 10:29 PM | #13 |
24330
Rep 191,065
Bump!
11-23-2016, 02:36 PM | #14 |
24330
Rep 191,065
Bump!
11-25-2016, 10:40 PM | #15 |
24330
Rep 191,065
bump!
11-30-2016, 01:55 PM | #16 |
24330
Rep 191,065
Bump!
12-11-2016, 11:28 AM | #17 |
24330
Rep 191,065
Bump!
01-06-2017, 10:49 PM | #19 |
24330
Rep 191,065
bump
01-12-2017, 06:38 PM | #20 |
24330
Rep 191,065
bump
01-17-2017, 05:06 PM | #21 |
24330
Rep 191,065
Bump!
01-20-2017, 05:28 PM | #22 |
24330
Rep 191,065
bump
