05-04-2023, 10:50 AM | #1 |
Builder of Special Cars
204
Rep 491
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
center headrest in rear seat. removal ?
I find it obstructive to my rear view.
Is it possible or has anyone removed the top of the center arm rear for the x5m ? I’m surprised bmw even has it. Most others don’t have a center headrest in the rear. At least my m3 7 don’t. Thanks |
05-04-2023, 08:14 PM | #2 |
Rep 114
Slide it to the highest position... Locate the small hole on one of the poles... Use straight pick to push into hole and activate the release.... Pull up while doing so.
Good luck. |
05-04-2023, 09:19 PM | #3 |
204
Rep 491
my center headrest is integrated into cup holder, i don't think it can move up.
05-04-2023, 10:46 PM | #4 |
Rep 402
Couldn't find anything that helped on the E70 section of newtis. I'm assuming you need to pop the cup holders out and you might find some fasteners in there?
05-05-2023, 12:21 PM | #5 |
204
Rep 491
I'm going to look, but they don't seem to pop out, its all one assembly, but i will see. Does everyone else have these or is it only the X5M ?
05-05-2023, 12:47 PM | #6 |
Rep 402
05-05-2023, 12:48 PM | #7 |
204
Rep 491
05-05-2023, 12:52 PM | #8 |
204
Rep 491
I cant seem to find the center arm rest for the non X5M other than the one pictured already with it integrated..hmm
https://www.realoem.com/bmw/enUS/par...0d&mg=52&sg=20 Non M have 52207171154 and M have 52207232952 With those with the Non M, so you can pull the head rest off of it (although it doesn't show that on real OEM) ? anyone have pics of the 52207171154, non M version? Last edited by JellyStyle; 05-05-2023 at 01:08 PM.. |
05-05-2023, 01:30 PM | #9 |
Rep 402
Mine has a 3rd row so it is completely different. But yes. I can take my center headrest out.
I found this picture though. https://wolfautoparts.com/seat-armre...7-ps53133.html Looks similar to my E60 which has instructions for removing the cup holders here. Maybe give it a try and see if there is some hidden hardware if yours looks similar? |
05-05-2023, 02:50 PM | #10 |
204
Rep 491
I wonder if removing the cup, will allow me to remove the headrest though.
Very surprised by this, its very big in your view of the rear. Could be an ugly change but i will dig into it and see if i can remove it, or try to source a NON-M arm rest from a junk yard even. |
05-05-2023, 07:27 PM | #11 |
Rep 402
It looks like they are separate pieces so I would imagine they're fastened together somehow..?
