      11-21-2019, 12:38 PM   #1
belverud
Drives: 2012 X5 2013 E350
Injector #5 issue
Hello everyone, my wife drives a 2012 X5 35i that has an injector issue. The injector was replaced however the issue is still there. After further investigation is seems to be a conductivity issue (split/damaged wire casing?). Does anyone know where the injector 5 pin location would be in the PCM/ECU? My thought is to run a new wire directly from the source. Thanks.
