      06-28-2017, 07:56 AM   #1
SyL3nTFoRcE
Drives: 2008 335xi
Dam PDC fell infront bumper
Hey guys does anyone know how to remove the front bumper to put the PDC back in place?
Its the corner piece that fell in its still alive since it beeps everytime and it shows its close to an object. I read that it is taped or glued in not sure if that accurate? Let me know
If there is a way i can do this without removing the bumper that would be great. Going to give a go at it this weekend so hopefully ill get enough info by then
Thanks in Advance
      06-28-2017, 09:13 AM   #2
jcm3
Drives: F85 X5M, 07 911 TT
which one is it..if its the ones under the intercooler you can change those by removing the wheel well covers and splash shield.
      06-28-2017, 09:18 AM   #3
SyL3nTFoRcE
Drives: 2008 335xi
yes it is, its on the bottom driver side part of the bumper near the corner. I was thinking that but didn't want to start taking parts off to only find out i could've done it another easier way.
Is it true these things are taped in and have no plastic holding piece? Ive been told i can glue it on the inside to hold but i don't know how true that is
      06-28-2017, 01:53 PM   #4
jcm3
It's a clip that holds it on the backside
      06-29-2017, 09:02 AM   #5
deansbimmer
Mporium BMW
deansbimmer's Avatar
3751
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
The sensor clips into a plastic holder. The plastic holder is fused to the bumper shell, but the holders can pop loose eventually. You can glue the holder back onto the bumper from the inside but you need a special 3M ABS bumper glue if you want it to hold permanently. JB weld etc may or may not hold it long term.
      06-29-2017, 09:12 AM   #6
jcm3
I used window adhesive (urethane) like Betalink or Sikaflex and it hold great and has some give.
      06-29-2017, 09:28 AM   #7
SyL3nTFoRcE
Drives: 2008 335xi
O I see, Dam the part that is supposed ot be on bumper is broken off, i do Have a hot glue gun to use for now but i think i might look up the bumper abs bumper glue to do it once and get it over with. I was going to repaint the bumper but ill have to wait for that now.
