03-18-2021, 07:56 AM | #1 |
Rep 46
Car is "waking up" every 1min 15sec, draining battery. CAS issue?
Bought a 2011 128i (Auto, N51, with 77k) a month ago from a dealer that had just had a new battery installed. Dealership (says) it got it from auction with a dead battery and from what I can gather, used it daily until they sold it to me. Battery was registered though when they replaced it.
When I drive it every day it's fine. But after 48 hours it'll drain past the point of starting. I did all the standard parasitic drain tests until I figured out that my car has comfort access, and that it's not working. Remote buttons work to open doors, and with the key in the ignition hole the car starts. But none of the handles unlock with the key in my pocket. Interestingly, even with all the doors unlocked using the key fob, the trunk switch on the trunk still doesn't work (but the physical switch is tested as good). All other ways to open the trunk work (except with key in pocket obv.). Anyways, pulling up INPA it shows that my (only) key is key #2. Just to mention, I tried some thing I read about where you hold the lock/unlock button on the center dash plus the start/stop button and using that to "re-learn" the key. But it had no effect. Battery in remote is at 3.0v on multimeter so I assume it's good. So here's what happens. The car goes to sleep after 20 or so minutes in that the light at the Park Selector goes out. But then every 1min, 15sec the mph/tach needles twitch momentarily, and the start button illuminates for 15 seconds and then goes out again. Park selector light stays off during all this. But the car draws 1.45 amps while it happens. Otherwise it's pulling .34 amps (still too high). So I'm thinking that something is not working right with the CAS. And it's causing this "wake up" cycle. But I have no idea what to do outside of an expensive dealership visit. I replaced the Passive go module in the trunk, thinking it got wet at some point and fried, but no change. It was cheap, but I did this before I really started understanding the problem or the car. I cleared all the module codes in INPA, and then re-read them 48 hours later after driving 100 miles. See the attached sheet with what codes are popping up. Ignore the TPMS stuff (I think), my aftermarket wheels don't have sensors in them. Last edited by turbodriven; 03-18-2021 at 08:09 AM.. |
03-18-2021, 07:58 AM | #2 |
Rep 46
Does anyone know how to use INPA (or whatever) to test individual door sensors and CAS antennas, etc. I know you can, I just don't know how.
03-18-2021, 11:32 AM | #5 |
Rep 1,146
reading your post, we have the same issue except for the following
1> my battery does not die 2> My CA works, for boot and start stop (i.e. key in packet) 3> I have a convertible and the fob opens and closes 4> I was going to change the CA module in the trunk, but didn't yet I use ISTA, I can get you some screen grabs of what you can check you should be able to check 1> The battery charge over 5 days 2> The battery % charge 3> Current drain, how often the current is over 80ma 4> How many times the car is being woken up 5> You can test the door handles 6> You can test the wireless modules In our cars, there is 4 or 5 wireless modules 1> 1 in each door handle 2> 1 in the boot 3> 1 in the inside of the car (middle I think near the center console) 4> 1 in the front by the windscreen Have uploaded a PDF for comfort access let me know if you have ISTA, and I can walk you through |
03-18-2021, 11:34 AM | #6 |
Rep 1,146
My CA passenger stopped working after a 3rd party windscreen repair was a total bodge, I suspect water egress and a damaged module,
windscreen was howling, but I managed to fix it, probably after the damage is done |
03-18-2021, 11:35 AM | #7 |
Rep 1,146
OH did you restart the CAS module ?
After working on the CA, and replacing, you need to restart the CAS ? That PDF says so as well. I was too scared to restart mine, as I didnt want to have a worse day !!! |
03-18-2021, 06:53 PM | #8 |
Rep 46
Thanks for the PDF. It'll give me some overall knowledge of what I'm working with.
All I have are the BMW Tools. INPA, NCS Dummy and Expert, Tool32. Etc. Where can I get ISTA? Is it free like the BMW Tools? If I can get my hands on it, some direction on how to use it to test will be invaluable! |
03-18-2021, 07:49 PM | #10 |
C2H5OH
3920
Rep 2,145
ISTA-D is a substantially larger download / program. I think it's easier to use though.
I think this is the one I used,,, I can't recall if there is a key or anything. https://mega.nz/file/a1wUmYCD#G0C3_H...o9uQ4EpxjI8oZs |
03-18-2021, 08:02 PM | #11 | |
Rep 46
I replaced the one in the right trunk, the passive go module, even though it looked clean. Aside from the missing warranty seal. The one behind the headlight switch, I think is called the CAS module, it's black. But you can't just swap it out. It has to be programmed to your car. As I understand. Given it's location I don't know how it would get wet. Unless a sunroof drain failed maybe? That happened in my Durango once. |
03-19-2021, 06:54 AM | #12 |
Rep 1,146
yeah that's common as well, I managed to pull my CAS module out, and take it apart, all looked ok, but again, I didnt wanna spend too much money plus it needs coding but good point
03-19-2021, 06:58 AM | #13 | |
Rep 1,146
The trunk module is the CA Module (comfort Access) and looks after all of the CA, that doesnt need to be coded. (looks after CA doors, boot, and yes keyless start and all that gubbins)
Yes behind the headlight is the CAS, and needs to be coded, but it is easy for it to see water leaks, would be worth to check it, I did mind, but wether a visual check is good enough. In Ista you can restart modules, I'm hessitant to restart the CAS I restarted the CA module though Quote:
03-19-2021, 06:59 AM | #14 | |
Rep 1,146
My mate loaded up all the BMW software, it's be reingold, it's "hmm" not officially released by BMW and you can get uploads,
if for sure you do, I can give you some screenshots when I was trouble shooting I used it to find were the fault is Quote:
03-19-2021, 07:32 AM | #16 | |
Rep 46
03-19-2021, 07:43 AM | #17 | |
Rep 1,233
03-19-2021, 08:12 AM | #18 | |
Rep 46
Also note, that I'm not pulling any error codes for the CAS. INPA always says "job status OKAY" for that module. I am pulling an A0A7 code in the PGS module though (passive go system). Despite it being a good module. Nothing pulls up as a description on that code when searching BMW fault codes. But I found somewhere where it was called a "TAGE_BFT_WUP_no_response" error. Tage is the door handles I think, not sure what BFT is, but WUP is "wake up"?? and No response is obvious. That's why I want to test the door handles. Edit: I just discovered that BFT is "passenger front door". So my CA module error code is "Passenger front door module, wake up, no response". If I can test and confirm it's bad, maybe I just found my problem. Maybe. I wonder if "disconnecting" that module will cause my sleep issues to go away? Or just create more errors? https://static.nhtsa.gov/odi/tsbs/20...43566-9999.pdf Last edited by turbodriven; 03-19-2021 at 08:58 AM.. |
03-19-2021, 10:49 AM | #19 |
Rep 6,196
Usually it is one the handles that goes out first. 10 min job to pull off the outer handles, disconnect the two connectors going to the handles and see if that fixes the battery drain issue.
Often when a handle shorts out, it will be warmer than the other handle as well. |
asbrr544.50 |
03-19-2021, 10:53 AM | #20 | |
Rep 46
03-19-2021, 01:57 PM | #21 | |
Rep 1,146
Yeah it's called the "passive Go, comfort access module" it basically does everything to do with the CA before it hits the CAS module,
03-19-2021, 02:00 PM | #22 | |
Rep 1,146
yes, that sounds like a good bet, the pas handle, in my case I can't spend $500 for a new one, the handles can't be painted and are special order from BMW, UNLESS you get one the right color of ebay, they start around $75
I was thinking of doing that for a test. I have INPA, dont really used it LOL. Quote:
