06-25-2012, 08:25 PM | #2 |
Rep 1,195
Just got them myself on the staggered 20's. There is a noticeable difference in ride yet they handle great in high speed maneuvering. The tread pattern is good looking as well. For the money they seem like a winner.
06-26-2012, 07:01 AM | #5 |
Rep 5,730
Drives: '24 iX50; '23 i4 M50
Did you guys happen to consider the Toyo Proxes STII, and if so, why did you go with the DWS?
I'm trying to decide between the two...
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
06-26-2012, 08:04 AM | #6 | |
Rep 294
1. Continentals tend to be more geared towards luxury vehicles 2. The Toyo's are engineered more for trucks/suvs & I just thought the ride quality may be not as plush as the continentals |
06-26-2012, 08:15 AM | #7 |
Rep 1,168
I can't comment on DWS on X5 and how they compare to Proxes, but I have them on my other car (Mini). While they do provide much better ride than the Dunlop run-flats they replaced, they are rather noisy, which is disappointing as I was expecting improvement over Dunlops.
So for myself I've decided to go with Proxes for X5 since you can rotate them left-right to address the excessive inside wear in the rear. |
06-26-2012, 09:10 AM | #8 | |
Rep 1,195
06-26-2012, 10:28 AM | #9 | ||
Rep 5,730
BTW, you could also rotate the DWS left-right, but I understand why you would want to try the Toyos. Toyos are also less expensive. Quote:
I wonder between the two which would be better in light snow.
06-26-2012, 11:46 AM | #10 |
Rep 389
If I remember correctly, Les Schwab will fix the punctures in Toyo tires free of charge. Not sure if this goes as far as replacing the tire when sidewal is damaged, but somethign to consider.
Seems like Continental DWS can only be purchased from TireRack. How's warranty handled with TireRack? I am reading about lots of vibration issues with ContiDWS. If stores don't carry them, could be a problem waiting for days for replacement from TireRack.. |
06-26-2012, 12:24 PM | #11 |
Rep 1,133
I have the proxes stII's with about 7,000 miles on them. I also looked at the DWS and was worried about some of the reviews. Prices are about the same now on both tires. Here's the positives on toyo. I've only used 1/32 of tread in 7,000 miles. There's 11/32 of tread on the tire so I'm guessing it's safe to say i'll get 60-70k Miles out of them. They're whisper quiet on the interstate, but a little hum around 20-30 mph. Excellent on not hydroplaning and excellent wet grip. Now for the negatives. After 7,000 miles one of the two back tires has developed a vibration that starts around 60mph and progressively gets worse all the way up to 100mph. BMW determined it was the tires after they put a completely new set of wheels and tires from another X5 on mine and the vibration went away. So they checked the run out on my wheels and they were true. Dealing with toyo on warranty hasn't been easy. One customer service rep was nice, while another was rude and wouldn't help me even though I have the receipt for purchase. They're now replacing the two tires, but they're not covering shipping or labor to mount the new tires. Hope this info helps you guys!
It's good to be bad
06-26-2012, 12:41 PM | #12 |
Rep 1,168
No, DWS have 'outside' designation, so if you have inside wear, you can't rotate the tire on the rim and put it on the other side (=to make inside outside, so to speak).
06-26-2012, 01:03 PM | #13 |
Rep 5,730
Oh, you were actually referring to unmounting the tire and reversing it. I was talking about being able to rotate side to side.
06-26-2012, 04:14 PM | #14 |
Rep 294
Just had the continentals installed & drove a few miles on the freeway.
First impression(s): 1. Quieter, smoother ride to the point that I know hear my stock exhaust tones a bit more than before. Only thing I can think of is the OEM Bridgestone rft mask the sound 2. Steering wheel turns much easier than before 3. Car seems a bit lighter probably due to less weight with the non rft's 4. Car feels a bit more top heavy; I noticed the Continentals look a bit smaller than the OEM rft's but the guy at America's Tire Store said the Continentals are not as square as the Bridgestone. Continentals are a bit rounder on the edge. Makes sense that it may lean a bit more than in turns. |
06-26-2012, 04:45 PM | #15 | |
Rep 5,730
I too read reviews that the Contis appear a bit smaller, skinnier from the rear (although not sure how a 315 tire could look skinny!). Would you be able to take a pic from the rear? One good thing about the Duns was their stance from the rear. Thanks
06-26-2012, 04:59 PM | #16 |
Rep 1,195
My rear Conti's look like I'm driving on tipped over 55 gallon drums!! You're right though, they aren't as square as the Dunlops but the stance is not much less aggressive and I'll give up that slight edge for what's gained in comfort and all season traction.
06-26-2012, 11:23 PM | #17 | ||
Rep 294
06-27-2012, 03:28 AM | #20 |
Rep 123
Spare?
What did you do about a spare, if anything?
Any thoughts on using "Spare Tire in a Can" sealer in lieu of a real spare? If a sidewall gives out on either type tire (RFT/non-RFT), I think you're out of luck without a spare, so what's the difference? |
06-27-2012, 03:39 AM | #21 |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
I thought Conti's were a little too soft a rubber for a SUV?
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
06-27-2012, 04:28 AM | #22 | |
Rep 294
I have AAA towing as well so I think I'm covered to an extent. |
