      09-04-2011, 04:07 PM   #1
mreuterusa
Drives: X5
E70 CIC retrofit part number question
I try to find the correct part number for my 01/2009 E70 with CCC but swap to CIC soon.
I do have a CIC unit from Europe and almost all parts together.
What I am missing the the plastic cover and there are 2 different ones on realoem. One shows only plastic cover and the other one includes TV function but also Navigation ??
I also try to find the part number for the power connector I have to change on the CID screen but only find 61136954526 CID CAN/power connector
and 61319167196 for the USB port USB Port.
Could someone help and confirm the correct cover and if this is the correct number for the USB port and power connector to switch to the new CIC system?
08 COVERING CENTER SCHWARZ 1 51456967464 $54.43
For vehicles with
TV function
or
On-board monitor with TV
or
Navigation system Professional
S601A=Yes
S602A=Yes
S609A=Yes
08 COVERING CENTER SCHWARZ 1 10/2009 51456967469 $54.43
08 COVERING CENTER SCHWARZ 1 10/2009 51456967464 $54.43
      09-11-2011, 08:04 PM   #2
mreuterusa
Drives: X5
Originally Posted by nelson29 View Post
To avoid confusion i'm gonna list an up to date P/N needed for the retrofit.
2004-2007 Pre-LCI owners that are cool with keeping their current idrive controller.
CCC Owners:
61119185171 CIC HD Screen cable
61319167196 USB Port
61129196805 USB Port cable
51456976361 CIC Center trim
M-ASK Owners:
You will also need a CCC center that goes under the CIC trim
This how it looks, its #15but you have to get your correct wood color.
RealOEM.com BMW E60 530i Trim panel dashboard
Pre-LCI owners will also need to change the AC console to an LCI one so there wont be no gaps in between the switches.
*** For those who want to use the new idrive controller you will have to remove the armrest, cut around and remove your current idrive controller module.Purchase a new center trim($150-$300)remove the ashtray and relocate it( you will need an LCI ashtray). You will also need a new shifter trim. You will also need to cut where your current ashtray fit to fit the new center trim. You also need to purchase the LCI set of covers that goes under the CIC trim. #16 RealOEM.com BMW E60N 528i Retrofit, fine poplar wood trim, dark
Will also need the the idrive contoller trim and bracket P/N 51169155970, 51169155987 that will have to be source from Europe. Can not be orderred from a North American dealer***
2008 to early 2009 build LCI owners that are cool with keeping their current idrive controller.
CCC Owners
M-ASK Owners
this is how it looks, Its #16 but you have to get your correct wood color
***For those who want to use the new idrive controller you will have to remove the armrest, cut around and remove your current idrive controller module.Purchase a new center trim($150-$300) Will also need the the idrive contoller trim and bracket P/N 51169155970, 51169155987 that will have to be source from Europe. Can not be orderred from a North American dealer.***
Late 2009 owners with the new Idrive controller
CCC Owners
61136954526 CID CAN/power connector $2.62
61119185171 CIC HD Screen cable $35.94
61319167196 USB Port $25.78
61129196805 USB Port cable $26.02
51456976361 CIC Center trim $31.78
M-ASK Owners
      09-11-2011, 11:05 PM   #3
apw2607
Drives: 2024 X5 50e M-Sport
For the e70 CCC to CIC retrofit, you don't have to "cut" anything. Simply buy the correct parts and its all very straightforward.
The above post is just confusing.
      09-14-2011, 02:11 AM   #4
mreuterusa
Drives: X5
That is the reason I post this. What is the correct part? The CCC monitor has a different power connector and needs to be switched and I found only 54526 CID CAN/power connector. Is this the correct one?
For the CIC cover I found this:
For vehicles with
TV function
or
or
S601A=Yes
S602A=Yes
S609A=Yes
Is the TV option with navigation or the only "schwarz (black) "one the right one?
