03-09-2017, 11:32 PM | #2 |
Rep 728
Is it only from driver or passenger side or both equally? Is there any vibration in the steering wheel? How old are the front pads/rotors? Did it rain while you were running errands? Does it happen with the HVAC completely off? Did you run over anything? Did you do a quick look under the car?
I'm thinking belts or brakes. Could be the brake dust shield scraping against the rotor, or the pad sensor scraping on the rotor, or the caliper sticking on one side, or wet brakes. If it was the caliper sticking you would feel vibration at higher speeds and one caliper would be hotter than the other. Could just be a belt also since the sound in the video has a pulsing to it like engine noise, but increasing with "speed" doesn't necessarily relate to engine speed, but vehicle movement so likely in the driveline. I'd take a look at the whole front axle area if you get a chance. Sometimes road debris can hit dust shields or heat shields which rub on rotating components like drive shafts or axles. Check out the brake pads to see the wear level also, when it gets down toward the sensor it will start to squeal. It could be the AC compressor clutch, or a pulley, or a number of other engine things too. Hard to tell since the sound is gone now.
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
MrGermanLover56.50 |
03-10-2017, 07:57 AM | #3 | |
Rep 125
