03-01-2017, 02:28 AM | #1 |
Rep 55
Mixing RFT vs NRFT
Now time to change my rear Bridgestone RFT's 315/35x40 tho my fronts (also RFT) 275/40x20 still good for another year. Thinking of getting Michelin Lattitude 315's Non-RFT for the rear.
Question: Will there be any issue if i continue with RFTs upfront and non-RFT's at the rear? Any experience on running with this mix? Kinda too early if I change/dump the RFT fronts together with the rears. Thoughts? |
03-01-2017, 11:30 AM | #2 |
Rep 994
There isn't a problem with mixing tires. But the tire circumfrence NEEDS to match within 1/8" front to rear. So typically the recommended response for most ALL AWD vehicles, and even from BMW themselves, is to replace all 4 tires at the same time.
Or else there could be issues with the center diff overheating and grenading itself by having to constantly deal with a front axle spinning at a different rate than the rear. |
03-01-2017, 11:38 AM | #3 | |
Rep 728
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
03-02-2017, 01:47 AM | #4 |
Rep 55
@mitch808, @jandref321: appreciate the insights. If i go with the current tire sizes, the circum diff bet front & back are within 1/16. So minimal discrepancy. But I noted possible overheating and potential t-case problem you shared. Will consider these risks very carefully.
Cheers & thanks, |
03-02-2017, 08:59 AM | #6 |
Rep 728
He said the car would studder as if hydroplaning and eventually they got some lights on the dash and took it to an Indy. The tires were new and a different brand. The difference was this was an X3 not X5. I imagine the tires had big wear in the front and the new brand had a different overall diameter because of tread pattern or something. There are probably a lot more options and variances with the X3 tires sizes since the are a square setup with large sidewall so many companies make them different ways.
03-02-2017, 09:21 AM | #7 |
Rep 2,736
Just replaced the rear tires and not the fronts and the difference in tread depth grenaded my transfer-case. No lights of any kind just crazy shuddering when turning hard left or right.
It wore out the clutches. Unfortunately the transfer-case where of a poor design in the E70's even BMW had to redesign it 4 times before getting it to be less touchy. Look it up, it was superseded at least 4 times with different design iterations. |
omgboost56.00 |
03-04-2017, 12:38 PM | #8 |
Rep 521
I'm not sure how applicable this is, but I did this exact thing with my 135i. I put non-RFT Michelin PSS in the rear and kept the Bridgestone RFT in front. It was very unstable and downright scary to drive. I got matching Michelin PSS in the front shortly thereafter.
03-08-2017, 04:11 AM | #10 | |
Rep 116
Here are some good information from Tire Rack http://blog.tirerack.com/blog/make-d...ead-this-first http://blog.tirerack.com/blog/make-d...?affiliate=FH8 |
