12-31-2018, 08:17 PM | #1 |
Rep 828
Door Locking/Unlocking Not Working
Hi folks. Happy New Year. I searched a while to find this exact problem, but couldn’t find a solution. My father’s ‘08 X5 is having lock/unlocking issues. Both the key fob and central lock button inside stopped working for a couple of days. The fuses are fine and no DTCs were found. The next day, everything worked as normal. Is this possibly a sign of failing door actuator(s)? Has anyone else had this experience? Thanks in advance.
12-31-2018, 09:42 PM | #3 |
Rep 828
Thanks for the response. Unsure how old the fob battery is, but isn’t it rechargeable? It’s likely not the issue since the central locking button inside was also not working. Which module do you think may be failing?
01-02-2019, 01:19 PM | #4 |
Rep 13
I swapped from M Sport to X5M steering wheel and everything worked perfectly, same as most people who've done this swap. Obviously the only things that don't sync up are the 2 buttons (///M button and the music button below it) and what they control, but everything still works.https://www.carcoverworld.com/car-covers
01-02-2019, 10:05 PM | #5 |
Rep 828
Wha?
01-03-2019, 08:13 AM | #6 |
Rep 247
