12-31-2018, 04:40 PM | #1 |
Rep 67
Screw in sidewall - do I need to replace all 4 tires?
I have a 2011 E71 X6M (I'm posting in here because more traffic than the E71 specific forum )
I have a screw in the front passenger tire, in the sidewall, 3 shops said they won't plug/patch, I have to get new tires. The shop I'm getting tires from says I should do all 4 because doing 2 may ruin the center diff. These are snow tires 255/50/r19, if that makes a difference. Is this true? There's about 6mm tread on the effected tire, new they're 9mm, probably less on the backs because I like to have fun. |
12-31-2018, 09:36 PM | #2 |
Rep 728
I had the same thing last year...had to replace all 4. Transfer case is supposed to allow for small variance. You can try it, but maybe better off buying all 4. I’m still stuck with 3 used tires in the garage hoping (sort of) that I need them before they dry rot.
12-31-2018, 09:39 PM | #3 |
Rep 212
Drives: 2008 e90 335i, 2012 X5 M spor
I would do it, sucks but my car doesnt drive as smooth with 2 new and 2 old.
Going to get them changed soon. |
12-31-2018, 11:14 PM | #4 |
Rep 828
Shave the new one down to match the other three. Done.
01-01-2019, 03:06 PM | #6 |
Rep 212
Would work if he had a square setup. Mine are staggered.
01-02-2019, 03:35 AM | #10 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I just replaced one on my x5m. No issues with different tread depth on the tires. The cars are designed to tolerate some mismatch in size. Deal replaced my tire and said it should be no isssue. So far thousands of mile later they are right,
P.s. my front tires are a different brand, age then the rears. No issues. |
mrsoandso8.50 |
01-02-2019, 09:46 AM | #11 |
Rep 85
Drives: 2012 BMW X5 3.5i Silver
A hint. I have had discount tire give me all kinds of reasons why they could not replace just one tire. But if you bring in the wheel and a tire, they are more than happy to mount that tire for their normal mounting fees. So if you acquire the tire, either from them or ebay, and bring it in not on the car, they will do whatever you like.
G. |
mrsoandso8.50 |
01-02-2019, 05:17 PM | #12 | |
Rep 247
In my experience, this has worked like a charm. Once on my X5M, and once on my Focus RS. Worst case, I figured it was worth risking ~$100 + mounting to see if things were fine. Found tires with manufacture dates +/- 6 months and 0.5/32nds of tread depth to old stuff still on the vehicle. As another suggested, I too have found independent shops very willing to replace with used rubber. |
01-03-2019, 10:10 AM | #13 | |
Rep 491
+ 1 I have staggered setup. Front and rear tires of different brands. I have changed just a single tire many times. Its just a money grab tactic to ask for all tires replaced for a single puncture. You are not driving a Formula 1 race car which have milimeter tolerances. Road cars have very high tolerances. Don't fall for the tire dealer gimmick. Tell them to shut up and put a single tire . |
01-03-2019, 10:16 AM | #14 | |
Rep 491
If we keep changing all four tires every time we get a non repairable puncture, we will have to open a used tire business in our garage. |
01-03-2019, 11:08 AM | #15 |
Rep 728
Haha, thanks. I was halfway through the tires and didn’t want to risk it. I have a good friend who swapped just his rear tires on his wife’s X3 and the transfer case grenaded. He had to buy a used one and swap it in and then buy 4 new tires.
01-03-2019, 12:04 PM | #16 |
Rep 2,822
Drives: X5M F85
Get A Used Tire.
01-04-2019, 08:49 AM | #17 |
Rep 17
I changed 2 tires when this happened to me, and the tread ware difference was causing my traction light to flash when I went over bumps on the road. Car seemed to be acting up with it.. Bit the bullet and changed the other 2. All is good. Rather not risk it over tires. Even worse. X5M tires are not cheap
01-04-2019, 02:22 PM | #20 |
Rep 34
You guys must have too much money to waste. The reason to replace all tires is because the outside diameter is different in a worn vs. a new tire. What happens when one tire pressure is a little low (not recommended, but happens)? That tire diameter is also smaller, I would think BMW system can handle small diameter differences with ease without causing damage or alter performance.
01-04-2019, 03:17 PM | #21 |
Rep 491
We have four family vehicles. If we replaced all four tires every time one of us has a puncture, we would have a used tire dealership on our hands LOL
