      11-29-2018, 02:15 PM   #1
colinmartin
Drives: 2009 x5m
Just finished valve seals
Had a problem with the valve seals,which have been replaced but the engine was taken out, whilst it was out replace front and rear crank seals and cleaned the injectors ,put engine back in coded the injectors through rheingold , everything seamed ok , but now it keeps throwing errors , the engine was washed before it was put back so some of the electrics might have got wet
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
*** 2A2C:Mixture control 2 ***
Fault-Set 1 - ( 145376 km)
Balance throttle model (factor): 0.96 -
Intake manifold pressure: 41.00 kPa
number of revolutions: 640.00 rpm
Relative load: 27.00 %
*** 2A2B:mixture control ***
Intake manifold pressure: 38.00 kPa
*** 29E0:mixture control ***
Balance throttle model (factor): 0.95 -
Intake manifold pressure: 40.00 kPa
*** 29E1:Mixture control 2 ***
Intake manifold pressure: 42.00 kPa
*** 2B46:Mixture control, lambda adaptation, Bank 1 ***
average rail pressure Bank 2: 50.28 hPa
Engine speed: 672.00 rpm
Lambda adaptation sum mul. and add. Group 1: -29.69 %
*** 2B47:Mixture control, lambda adaptation, Bank 2 ***
average rail pressure Bank 1: 50.28 hPa
*** 0x0000: :sorry unknown fault ***
Any ideas where i should be looking, it would have been nice to actually have the car fixed for once , rather than always needing something ,
Sent from iPhone
      11-29-2018, 02:43 PM   #2
X5 MAN
Drives: 2011X5 50iM-Sport;2016X3 35i M
Just sell it. Why keep wasting money ?
      11-29-2018, 02:50 PM   #3
colinmartin
Drives: 2009 x5m
X5m running like crap ,practically worthless
      11-30-2018, 08:05 AM   #4
Ryan5034
Drives: 2019 X5 50i
I don't know what balanced throttle factor means but might be worth checking to make sure you don't have a vacuum leak somewhere. I realize that's a tall task buts it's got to be something simple like that?
      11-30-2018, 08:57 AM   #5
colinmartin
Drives: 2009 x5m
thanks I have been looking all day now the exhaust doesn't open when you hit the m button and for some reason the max a/c doesn't work f*&king car
      11-30-2018, 09:06 AM   #6
philly42
Drives: X5M, Z3M
I would start by replacing the upstream o2 sensors. If you have rheingold it'll narrow down the problem by telling you which code is really causing the problem. Then you can run tests within the system to confirm. At the end it'll spit out what parts needs to be replaced.
      11-30-2018, 09:26 AM   #7
philly42
Drives: X5M, Z3M
FYI, If the throttle body angle from one bank deviates greatly compared to another bank it'll trigger a code. There's many possible causes for this. If you get the code at idle, it could be related to the ccv system, huge vacuum leak, or o2 sensors. Under load it could be related to a vacuum leak or o2 sensor.
o2 sensors are really sensitive and can damaged easily. The good thing is they're easy to replace. Just make sure you wire them up correctly to the right bank or else you'll get a shit load of codes. It was easy to spot the issue in rheingold as there's a code related to the wiring of the o2 sensors.
      11-30-2018, 08:59 PM   #8
pearlpower
Drives: 2013 328i
Why would you code the same injectors? Also, pulling the motor , R&R injectors, and swapping out the valve stem seals is a large undertaking. Any number of things could have occurred such as crimped wiring, plug not fully inserted, timing, damaged injector, etc... Me, I would grab a good light and inspect every wire incl ground, plug, and hose. It does not take much t get where you are at. Hopefully you disconnected the negative battery terminal first.. GL.
      12-01-2018, 02:23 AM   #9
colinmartin
Drives: 2009 x5m
the reason for the recode of injectors is that the Rheingold had a different set of numbers stored not relating to any of them ,I chose to have the injectors cleaned while the engine was out ,I am going to get my light out today and do exactly that, and yes the battery was disconnected. I must say that the mechanic that worked on my car is a family member and has done numerous things before he is very methodical
      12-01-2018, 02:30 AM   #10
colinmartin
Drives: 2009 x5m
the o2 sensors are almost new as I had just changed them when I installed ar sports cats about 3 months ago,i also change every vacuum pipe on the motor I did notice that the pipe going into the crankcase number 1 in pic had a bad o ring so I changed that yesterday
      12-01-2018, 08:53 AM   #11
colinmartin
Drives: 2009 x5m
I have notice now it backfires when decelerating and it is idling just below 500rpm
      12-01-2018, 05:04 PM   #12
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Codes still the same? Have you reset adaptations?
      12-02-2018, 02:23 AM   #13
colinmartin
Drives: 2009 x5m
yes I have reset adaptions
      12-02-2018, 05:06 AM   #14
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Most likely your Injectors if you are 100% sure your 02 sensors are solid and no vacuum leaks. Either they were damaged when cleaned or something is up with your coding. I would double and triple check you coding of them. If you have the $$$ Then I would say just install a new set and be done with it.
      12-03-2018, 04:40 AM   #15
colinmartin
Drives: 2009 x5m
just checked the injectors they are runnning perfect ,rechecking throttle bodies now incase of leaks .
      12-04-2018, 09:46 AM   #16
philly42
Drives: X5M, Z3M
swap out those o2 sensors then reset adaptation. It's one of the cheaper items to replace in fixing this issue. start there and work your way up to the costly injectors.
      12-04-2018, 10:03 AM   #17
9vapors
Drives: CB X5M
Make sure that the vacuum lines running along the top of the motor are plugged into the black vacuum canisters on both sides of the engine. Make sure they are on tightly. I had a scenario with similar issues where I tightened the vacuum canister downs and one of the lines pulled off on the back and I didn't see it. Not sure why these don't have hose clamps on them.
      12-04-2018, 06:00 PM   #18
What are you using to scan your car and does it have datalog or have a live view? If I were in your shoes I would be logging the air/fuel, vacuum, fuel pressure, throttle plate angle, etc of each engine bank and comparing the two for variances. A quick a dirty one that is easy to hook and does data logging and live views is this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. This is how I caught my bank to bank boost variance and also intercooler temp variance. Easier then a laptop =)
      12-05-2018, 12:23 AM   #19
colinmartin
Drives: 2009 x5m
I have been using my Carly, but the mechanics are using Rheingold ,funny thing happened last night my carly couldn't get comms from the engine ,I must have tried at least 20 times I'm thinking when they put the motor back one of the connections is either weak or not connected. Its going back in today to see the electrician to see if he can find anything. I have an appointment with the tuner tomorrow to update my tune and put it back on the dyno
      12-06-2018, 12:42 PM   #20
colinmartin
Drives: 2009 x5m
Took the car to the tuners today . They took it back to stock and its still popping and backfiring on deceleration , they reckon its the injectors . I cant believe taking the decision to clean them prior to putting the motor back in has somehow screwed them up, anyway i have bit the bullet and ordered 8 as they don’t carry them in stock here and I don’t want to wait ages for them to turn up 1 by 1 , hopefully after this i might have an improved car , to be honest that would be the best christmas present ever
      12-06-2018, 02:13 PM   #21
9vapors
Drives: CB X5M
You could just test them in ista instead of buying all 8, but replacing them can't hurt either
      12-06-2018, 02:16 PM   #22
colinmartin
Drives: 2009 x5m
for some reason the guy that has the Rheingold and ista has light version of the software ,because mine is an early 2009 it doesn't have all the functions
