07-20-2010, 04:21 PM | #1 |
Rep 399
Centre Bore measurements for X6?
Hi. I bought some new wheels for my X6 (which will arrive in 2 weeks), and I am not sure if these wheels will fit perfectly on the X6, or i will need center rings. Does anyone know?
The measurements are: Front Wheels 20x10 pcd = 5x120 et=40 centre hube = 74.1 Rear Wheels 20x11 pcd=5x120 et=37 centre hub =72.6 So obviously i am referring to the centre hub measurements of 74.1 for the front and 72.6 for the back? |
07-20-2010, 04:26 PM | #2 |
Rep 399
ok i kind of found the answer myself!
http://www.bimmerforums.co.uk/forum/...e-sizes-t7759/ X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread. There is a difference of 0.1 mm. Probably they intentionally did this. Thus i expect they would fit right on without rings? |
07-13-2011, 08:49 PM | #3 |
Rep 2
The info on that link is wrong as it pertains to the bolt thread. I had to learn the hard way. Its actually M14 x 1.25
I hope the hub sizes are correct as I'm about to purchase some wheel spacers. Cheers |
