      08-27-2016, 09:28 AM   #1
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Can I remove the front Drive Shaft
Call me crazy, I dont need AWD in the summer, what will happen if I actually remove the front drive shaft ? I might get DSC or 4x4 code when slippage is detected but other than that shouldn't affect anything ? Instead I might reduce losses and get some more ponies on the rears, pitch in your thoughts!
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      08-27-2016, 10:50 AM   #2
-c-
-c-'s Avatar
Drives: bmw
If your gonna go through the trouble to remove it just get the new one!
Then your good to go and no more worries.
Worst case keep it in their if it blows you get a new trans and engine maybe.
      08-27-2016, 01:44 PM   #3
machine
is also an E46 Fanatic
machine's Avatar
Drives: E70 35D
There is a recall on the front drive shaft....fyi
      08-27-2016, 04:11 PM   #4
007_e350
007_e350's Avatar
I knowww right!! .. but I just got a tune and exhaust, God forbid it snaps they'll blame everything on the mod
      08-27-2016, 04:50 PM   #5
007_e350
007_e350's Avatar
anyone knows torque specs on those ? I heard 300 ft/lb on the 330xi, x5 will be more
      08-27-2016, 10:45 PM   #6
-c-
-c-'s Avatar
Drives: bmw
Just revert the tune to stock if it does brake, I'd hardly think they would blame it on an exhaust.
      08-27-2016, 11:03 PM   #7
007_e350
007_e350's Avatar
Diesel exhaust has a ton of stuff ,exhaust recirculation hardware (EGR), Diesel particulate filter, Urea injection system (SCR) etc etc
      08-27-2016, 11:40 PM   #8
-c-
-c-'s Avatar
Drives: bmw
Well that's true didn't know you had the D!
      08-29-2016, 11:50 AM   #9
mitch808
Drives: 2012 X5 35i
Most full time AWD cars will require much more than a drive shaft removal. Often involving welding or manually locking the center diff. With all the computer guided shenanigans within the car, I'm sure you've also put the car into DEFCON 2....
Really not even sure how serious this post is to begin with, It's not even April 1st yet.
      08-30-2016, 01:47 PM   #10
094.8x5
Drives: black on black on black
Mine just came out of shop and i had them check for the recall while there,,was told it applies only to certian year/Vin #/production. Call Dealership to verify. Mine was blessed clean....good luck
