      08-16-2016, 05:39 PM   #1
Sick335
Drives: 335i / X6M
2013 X6M/X5M JB4 Stage 2 Tune Review
Cross post from X6M forum:
Hello Fellas,
2 week ago I had dropped off my car, a 2013 E70 X6M, with Terry from Burger Tuning for research and development of an aggressive tune. Having dealt with him plenty on the N54 platform I was confident something awesome would come out of it, and it sure did.
Car's mods are:
Kittyless Downpipes
Drop in Filter
JB4 + BCM Module
Compared to stock it's day and night. If my butt dyno is correct, I'd have to guess at least 100 awhp increase in power, but we will know for sure once I put it on a dyno. Throttle response, turbo spool sound, and exhaust are dramatically improved. Car sounds like a beast at WOT yet fairly quite and sophisticated during regular driving. Terry created 3 maps: 1. 91 octane conservative tune 2. 93 octane more aggressive tune 3. E30 map for maximum performance. I love JB4 and it's ability to switch maps on the fly right on your steering wheel.
The results were as follows:
0-60 was clocked in at 3.7 with a moderate launch. Stock time: 4.7 seconds
1/4 came in at 12 flat at 118.9 mph. Stock time: 13.0 at 110.5
I'll be taking the car to both the drag strip this Saturday and to a Dyno next week. I'll be updating this thread accordingly.
Would definitely recommend this product to my friends and my fellow enthusiasts. Install is a bit tricky, but well worth the hassle.
      08-16-2016, 07:19 PM   #2
Jax_415
Drives: 2013 X5M
So this will work without a tune correct? Also since u are catless does it turn the cel light off and put the 02 sensors in ready mode for smog?
      08-17-2016, 09:09 AM   #3
mirob
mirob's Avatar
Drives: M3CX
Is there a difference between the JB4 Map 1 and the Stage 1 map. If yes, what is it?
I can't get 93 octane where I'm at so Map 2 is useless to me. Not sure about Map 3...
I have the Stage 1 piggyback so I'm trying to figure out if this is worth considering.
      08-19-2016, 10:09 PM   #4
Sick335
Drives: 335i / X6M
Yup. All you need to buy is the JB4, no other tune necessary. Huge savings.
It comes with code reading, code clearing(yes, turns off cel), and a ton of other in dash options. Take a look on burger tuning website at all the stuff they offer, it's awesome.
      08-19-2016, 10:13 PM   #5
Sick335
Drives: 335i / X6M
Most definitely worth the buy.
Terry can create you a tune for any fuel.
I currently has 3 maps:
Map 1: 91 Octane. 13PSI
Map 2: 93 Octane. 15PSI
Map 3: E30(30% Ethanol or 10 gallons 91 6 gallons E85) most aggressive 17-18PSI
The difference is fairly noticeable switching between the maps, not to mention from stock to even most conservative map 1. Night and day.
Also, Terry can create a more aggressive Map 1 for you on 91 octane is you like. It's done that way for me because I asked to make Map 1 conservative. You can make it as aggressive as you like.
      08-20-2016, 12:00 AM   #6
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Isn't stock already 17.4psi?
      08-20-2016, 12:04 AM   #7
Sick335
Drives: 335i / X6M
Lol no. Stock boost is a pathetic 7-8 PSI
      08-20-2016, 12:46 AM   #8
m5james
m5james's Avatar
Per turbo, no? See this article I'm not allowed to post correctly lol
"...The N63 compression is at 10.0:1 while the S63 is at 9.3:1. Why the compression difference? The S63 runs more boost with 17.4 psi peak vs. the N63 hitting 11.6 psi of maximum boost pressure..."
http://www.***********.com/content.p...and-S63-motors
      08-20-2016, 04:43 AM   #9
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
Do you know of any plans to do a 98 octane map?
I won't be putting E85 in mine until I've verified all the lines/pumps are good for ethanol - A straight E85 map would be perfect for this engine.
      08-20-2016, 05:23 AM   #10
Cattivo
FDNY Engine 55
Cattivo's Avatar
I had the JB4 piggyback on my 335 which was a great tune that I could change maps on the fly, is this more or less the same thing meaning I will have to open up the ECU? would I need to unload my Active Autowerkes stage 2+ tune to run the JB4 or can they be married?
FDNY ENGINE 55...Liberalism: Find a Cure...http://www.xbimmers.com/forums/showthread.php?t=1127923
      08-20-2016, 12:32 PM   #11
m5james
m5james's Avatar
I'm doing meth, cheaper than mixing 100 octane while the water adds the benefits of cleanings the valves...the pros outweight the cons.
      08-20-2016, 12:32 PM   #12
m5james
m5james's Avatar
I'm running a Halim tune and he said I can run JB4 with his tune, I'll just need to send logs and he'll adjust AFR as needed.
      08-20-2016, 01:17 PM   #13
Sick335
Drives: 335i / X6M
Yup, this is the same tune as we had for the N54 platform, with some more cool add ons like the blue tooth logging. You don't have to unmarry, you can stack JB4 on top for additional ponies
      08-20-2016, 01:18 PM   #14
Sick335
Drives: 335i / X6M
I'd do meth, but I had a nightmare of an experience with it on the N54 platform, so I dont mess with it anymore.
      08-20-2016, 01:45 PM   #15
Sick335
Drives: 335i / X6M
The E30 and 98 Octane tune are essentially the same. I might run MS109 instead of the ethanol mix at the track tonight for better results.
      08-20-2016, 02:14 PM   #16
m5james
m5james's Avatar
Can you elaborate or have a thread to link?
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      08-20-2016, 02:45 PM   #17
Jax_415
Drives: 2013 X5M
Any plan on doing a group buy for this jb4 product maybe?
      08-20-2016, 03:07 PM   #18
m5james
m5james's Avatar
I asked for a discount based on being beta but he wasn't interested...a GB on the JB4/BCM combo would hopefully make it possible.
      08-20-2016, 04:11 PM   #19
Sick335
Drives: 335i / X6M
Dont have a thread, but it was just a nightmare. Constant leaks. A couple of times the whole tank leaked out into my trunk, car smelled like hell for months. Always some type of flow problems. Once you install meth and your tune becomes meth reliant, its a huge pain in the ass
      08-20-2016, 04:16 PM   #20
Sick335
Drives: 335i / X6M
I'm gonna see about getting one going.
      08-20-2016, 04:16 PM   #21
Sick335
Drives: 335i / X6M
Product is solid. I was the beta. Not sure why you want a discount when it is already less than half the cost of any other tune out there.
      08-20-2016, 07:35 PM   #22
protecon
*May contain nuts
protecon's Avatar
Australia
193
Good luck with your group buy. I bought one already without hesitation as I've been on at these guys to do a S63 JB4.
For $799+$150 (BCM) it's still half the price of other tunes and gives you many more options. These guys put much more into their development and pioneer products rather than duplicating and there's a reason why they're popular with the n54 platform.
Don't be cheap. Pay the man his money.
