03-25-2011, 06:19 AM | #2 | |
Rep 666
Search eBay for 'BMW x6 rails'. You'll get hits for both OEMs and reps. Looks like you'd have to have the plastic covers painted if you want them to match your car. Not so much of an issue if you're only leaving them on for a week, but perm is another matter. |
03-26-2011, 01:21 AM | #4 | |
Rep 666
http://www.xbimmers.com/forums/showt...ighlight=Rails Post #7 by motex It's a post for removing roof rails. I'm assuming that you'd do the reverse to install them. Here is some more info: http://www.justanswer.com/bmw/2t2tg-...-new-roof.html So it appears that there two things at play here: *the roof rail system and the optional roof rack. *The roof rail system apparently just being the threaded holes in the roof required to bolt down the rails. Perhaps since you can't order an x6 to include rails anymore, they just pre drill them all. *That would make sense to me... The ultimate answer would be for you to look under that trim piece on your roof to see if you have the bolt holes for the rails. *If you do, you should be good according to that second article right? (the 2nd reply at the bottom) |
